09-30-2018 10:24
09-30-2018 10:24
09-30-2018 10:49
09-30-2018 10:49
Hi, @Mercsable, the elliptical machine involves a lot of arm movement and possibly wrist flexion. Wrist worn heartrate trackers often do not work well with machines where a lot of wrist flexion is involved (rowing machines are a well known example).
In order to get the most consistently accurate heartrate during an elliptical workout, I would suggest wearing you you Versa a little higher up on your wrist (away from the bendy part) and also wearing it a little bit snugger. Hopefully that will help.
Welcome to the forums.
