@Jay1963 Is it only screen that is off? Is your Versa syncing? What happens when you plug it for charging? Try rebooting your Versa several times by pressing and holding the left and bottom right buttons together until Fitbit logo flashes. If everything else fails, try 3 button factory reset:
You may need to attempt the reset a few times to find the optimal times. Trying holding the buttons longer, as long as it's needed for the vibration to appear.
