07-10-2019 09:51
07-10-2019 09:51
How do I track a workout on a Stationary Bike at the gym?
07-10-2019 09:57
07-10-2019 09:57
Solved my own question. I edited the list of exercises to include "Spinning".
11-28-2019 17:24
11-28-2019 17:24
So how does that help me? How do you edit the list of exercises AND whilst editing what are you changinng ?
11-28-2019 17:25
11-28-2019 17:25
So how does that help me? How do you edit the list of exercises AND whilst editing what are you changing ?
01-13-2020 13:10
01-13-2020 13:10
This links to nothing. Not helpful at all.
01-16-2020 07:00
01-16-2020 07:00
Fitbit supports spinning. You can add shortcuts for this exercise to your Exercises app on Versa. Please open fitbit mobile app, tap on your profile picture and scroll down to Versa. Tap it and scroll down to Exercise shortcuts section. Tap it. You can add seven shortcuts. If all are taken, please delete some by swiping the shortcut you want to delete, then tap the '+' icon in the top right corner. Choose spinning to add. You can rearrange the order of exercises by dragging them up and down. Don't forget to sync your tracker! Next time you start your workout, just open Exercises app on your Versa and start Spinning.
10-08-2021 12:36
10-08-2021 12:36
There's a default excersise called "Spinning" which can be used to track stationary bike workouts.
06-06-2023 09:41
06-06-2023 09:41
Okay/. I have a Versa 4. I don't see how to edit the exercise. I'm using a stationary bike for rehab. How do I add that to my exercises? I don't see any way to edit the list on my phone app or on the fitbit itself.
06-06-2023 11:42
06-06-2023 11:42
Hello @JackBoughton and welcome to the Community. This is an older thread and your Versa 4 navigates very differently. Any indoor bike is tracked with the Spinning shortcut. All of your shortcuts are on the Versa 4.
When you swipe left/right on the Versa 4, you are navigating between your screen tiles. There is an Exercise tile that has three circles with exercise icons in them. They are Quick Start shortcuts. They are the last three shortcuts you used and, if you haven't used any, there are three default shortcuts. After you successfully track your rehab bike ride, one of the icons will be replaced with the Spinning icon. Next bike ride, all you need to do is swipe to that Exercise screen tile, than tap on the Spinning icon to start. Quick Start shortcut. I hope this helps.
Laurie | Maryland
