01-16-2019
04:41
16:17
DavideFitbit
01-16-2019
04:41
16:17
DavideFitbit
Hi 🙂
I am looking for the best way how to track ice skating. I tried Bike and Workout, but I want to know the distance (the best in kilometers) if it is possible. I wish they would add skating to the list. Thank you.
01-17-2019 14:51
01-17-2019 14:51
@PetraAlexis I think your best option is to use a standard Workout shortcut. Unfortunately, it will not give you an accurate distance. I have the same issue for my cross-country skiing. I start Workout manually and then change the name (in your case that would be Skating). It will probably show some distance but it will not be accurate. Perhaps you could add your idea to the Feature Suggestions Forum?
