02-13-2019 19:21
02-13-2019 19:21
I wear my Versa every day. It has been auto-detecting my normal (several times per week) group fitness workouts for the past year with no problem. For the last week, every workout has either not been detected or it has been categorized incorrectly with gaps in the workout and calories burned significantly lower than expected (by over 200) even for the right time frame. If I try to add the workout manually, it is still significantly off based on calories.
I realize that starting the tracking from the device may or may not help, but it doesn't explain what is going on with the auto-detect feature. The workouts that haven't tracked are cardio heavy (hiit, cardio kickboxing) and last 50 minutes so have never had any problem being intense enough to be tracked. Strength training I always have to track manually. I walk at least once a day, and while those had always previously tracked as walks, they have also been inconsistent and are showing up as elliptical workouts sporadically.
I am using an Android device. Every time I check the watch, it has been showing a heart rate so it doesnt seem like it is being caused by inconsistent HR data. I am not sure what is going on, but I am confident that the workouts are not being tracked correctly.
Best Answer02-13-2019 22:48
02-13-2019 22:48
Hi @saranic090 have you tried restarting your Versa several times? Try that and see how it goes with your next workout. Come backmif you are still having problems.
Helen | Western Australia
