04-05-2019 12:51
04-05-2019 12:51
Hi, so I wanted to know if I should be concerned that my Versa is sometimes glitchy and once in awhile it will freeze up. My Versa works fine and I noticed that it didn't glitch much until i switched over to a new phone. So I basically wanted to know if I should be concerned that my Versa is sometimes glitchy and if it's common. Thanks in advance!
04-05-2019 12:59
04-05-2019 12:59
Hi, try this: restart your Versa 4-6 times in a row by pressing and holding the left an lower right buttons togehter untill you see the Fitbit logo and release the buttons. See if this solves this problem. If the problem persists or reoccurs, contact Customer Support.
04-05-2019 12:59
04-05-2019 12:59
04-05-2019 13:01 - edited 04-05-2019 13:01
Thank you, do you think I should be concerned about my versa glitching? I got a new phone and since then it was kinda glitching.
Best Answer04-05-2019 13:05
04-05-2019 13:05
When the procedure I suggested solves your problem, you do not have to be concerned and the fact that it's happening since you have a new phone (which one by the way??) might be a coincident, unless the phone is not in the supported list of Fitbit, but that's something else. Keep me posted!!
04-05-2019 13:09
04-05-2019 13:09
I used to have my FitBit on a ZTE then I had I got it on the iPhone 6s and ever since then it has been glitching. I will try to restart my Versa. By the way thank you for your help I appreciate it.
Best Answer04-05-2019 13:11 - edited 04-05-2019 13:13
You're very welcome, that's why I'm around here to try to be helpfull. BTW, your new phone does not cause the problem cause it's supported by Fitbit, so just a coincidence!
04-05-2019 13:15
04-05-2019 13:15
Thank you for your help I restarted the Versa and it isn't as glitchy, my Versa is sometimes a little slow but aside from that is is working fine! Thank you.
04-05-2019 13:17
04-05-2019 13:17
Thanks, so you now know what to do when it happens again, besides that this procedure solves a lot of other minor problems.
