05-05-2018 11:37
05-05-2018 11:37
Versa is counting steps during Bike rides. Can anyone tell if this is something you can switch of?
05-05-2018 12:49
05-05-2018 12:49
Use the exercise function and select Bike it wont count steps or miles either for that matter
Manual is here
http://help.fitbit.com/?p=versa Its at the top of the page
Wendy | CA | Moto G6 Android
05-05-2018 12:56
05-05-2018 12:56
I select this function, and it is still counting steps. So disapointing 😞
05-05-2018 15:14 - edited 05-05-2018 15:14
and the problem is that we have exercises marked that we didn't do, unless driving now it's a phisical exercise 😕 (making the exercise goals totally irrelevant)
05-05-2018 18:38
05-05-2018 18:38
I like that it counts as steps so that it counts towards my daily goal.
05-05-2018 19:04
05-05-2018 19:04
That's cheating! 😄
05-19-2018 10:49
05-19-2018 10:49
I have observed this same problem. My versa uses 32.32.10.15. Is there a way to disable steps while biking?
05-19-2018 22:38
05-19-2018 22:38
I brought My Versa back to the store and buy an Apple watch.
So bad, I am a Fitbit fan! Charge 2 was doing just perfect with Bike rides...
05-20-2018 04:46
05-20-2018 04:46
I did not want steps counted while riding an indoor bike so I stopped using the Bike Exercise Shortcut and just manually add biking. That way, you enter the time you started, how long you rode and the mileage and the Versa will calculate your heart rate, calories burned and miles per hour - no steps.
05-20-2018 04:47
05-20-2018 04:47
@abissinian wrote:That's cheating! 😄
I agree!
05-21-2018 09:51
05-21-2018 09:51
It's a common issue between fitbit trackers (even those with smart track). We are asking fitbit to discount steps made during cycling activities, if you want this issue to be solved please vote this proposal, so maybe we can make them hear our voices...
06-29-2018 11:05 - edited 06-29-2018 16:49
I’ve had the exact same issue with my Alta and my Charge HR 2. Have spoken to them about this many times. My new Versa counts steps during a bike ride and as a result the calorie count is falsely elevated.
Today not only did it count steps during my bike ride, but it also thought I’d walked up 13 floors. When I take the watch off and place it on a table, it still displays a heart rate. It’s about time Fitbit solved this bike problem and I’d like an explanation for the other two issues.
08-23-2018 05:40
08-23-2018 05:40
This is so annoying, a company that must have tonnes of money and they can't even sort these simple issues out! People have been complaining for years now. My fitbit counts hundreds of steps in the car so I now have to use an app called travelbit to remove them.. this then goes in as an activity so my fitbit says "Goal met!" all the time, even if I havn't exercised! Now I've started cycling and the cycling activity counts steps too! what the hell! It counts thousands of steps in a short 30 minute ride.
08-23-2018 08:24
08-23-2018 08:24
@waffles_55 Agreed, $200 does not joke. You spend so much to get to know that you have to tweak your Fitbit stats after every commute to discount the extra steps. By virtue of this poor sensing of Versa, I'm awarded badges which I actually don't deserve. Such a shame.
08-23-2018 08:29
08-23-2018 08:29
I've only had mine a month and I've got loads of badges just from driving to work and back every day! They need to pull their finger out!
08-23-2018 08:34
08-23-2018 08:34
08-24-2018 08:48
08-24-2018 08:48
Why would you not want those steps to be included? I work hard at biking and put on a ton of miles so just because you walk/run means my miles don’t count. A mile walking on average =2000 steps. For biking it averages 250-450 per mile. I want them to count. It’s a workout! Your steps count when u lift weights! When I do kettle bell workouts! When I do boxing workouts. Why can’t they count when I bike?
08-24-2018 08:51
08-24-2018 08:51
I don't want them to count because they're not steps! Weight lifting isn't steps either!
08-24-2018 08:52
08-24-2018 08:52
I'm thinking of getting a samsung gear fit pro instead!
08-24-2018 09:15
08-24-2018 09:15
