06-13-2020
14:08
08:36
06-13-2020
14:08
08:36
Has anyone else had their heart rate go up over 200bpm? My Fitbit versa said mine went to 204bpm for a few minutes. I had done weights then jumped on the treadmill only walking at a semi fast pace then that happened! The day before it was 186bpm but that’s usually around my max when doing very high intensity. Could this be wrong? 🤔
06-18-2020 08:38 - edited 06-11-2024 09:16
Hi there @gem.h, welcome to the Community Forums. Thanks for bringing this to my attention, I'll be glad to help you with the high heart rate readings you've been getting from your Versa.
If you haven't done so yet, please restart your Fitbit Versa as described in this help article. Then, make sure about the following:
After this, monitor your Versa for the next 24 hours and see if the issue gets fixed.
Keep me posted, I'll be around.
06-19-2020 02:12
06-19-2020 02:12
Thanks so much for your reply, much appreciated! I’ll do this and will let let you know how it goes 🙂
06-19-2020 05:06
06-19-2020 05:06
Mine does this when walking
Best Answer06-19-2020 07:36 - edited 06-11-2024 09:16
Hi @gem.h, you're welcome. Keep me in the loop! 🙂
Hello there @Nealkat, thanks for stopping by. If your Versa does this when walking, please try the recommendations I've posted above and let me know how it goes.
Best Answer06-19-2020 09:13
06-19-2020 09:13
Best Answer06-19-2020 09:43
06-19-2020 09:43
I have done everything that has been recommended and still no solution. I just ignore the reading. The heart rate is of no benefit to me anymore, as well as syncing. It no longer does that either. Tried everything recommended. Also tried everything for the battery draining - nothing works. The update killed everything that was working on my watch.
06-19-2020 10:08
06-19-2020 10:08
This has also been happening to me this past week. My Versa says my heart rate is at 180 even when I’m sitting or resting. I have tried turning off the heart rate and turning it back on as well as resetting the watch multiple times.
please let me know how I can fix this.
Best Answer06-19-2020 14:40 - edited 06-11-2024 09:16
Hi there @rach293, @Nealkat, and @Kpillard. Thanks for letting me know that you've tried the steps I recommended above, I created a case for you and someone will respond as soon as possible. Due to recent events affecting our operations, we may need more than 7 business days to respond.
I'll be around if there's anything else I may do for you.
