06-02-2020
07:05
07:28
06-02-2020
07:05
07:28
Hi, My Fitbit versa is locked out and doesnt pair with my phone. Any suggestions? I have tried everything.
06-02-2020 07:35 - edited 11-08-2023 02:13
Hello there @Vijusher, welcome to the Community Forums. Thanks for taking the time to troubleshoot your Versa prior to contacting us.
I've seen you already contacted our Support Team, I'd suggest to keep the conversation with them as they'll know what's the next step to try after all the steps you've done so far. You haven't received a reply yet as due to recent events affecting our operations, we're taking longer to respond.
In the meantime, besides the steps you've done, you can perform a factory reset which is a different procedure. Please be aware that by doing a factory reset your apps, stored data, personal information, credit and debit cards and saved settings will be deleted from the watch:
We hope to get you back on track soon.
Best Answer06-02-2020 07:35 - edited 11-08-2023 02:13
Best Answer06-02-2020 08:34
06-02-2020 08:34
Thanks. I tried all the options you have mentioned but now luck. Will wait for FITBIT support to advice back.
Best Answer06-02-2020 08:46
06-02-2020 08:46
Hi there @Vijusher, you're very welcome. 😉 Thanks for confirming that you've tried the steps above.
We hope your issue is solved soon.
Best Answer06-02-2020 13:24
06-02-2020 13:24
