05-21-2020
22:32
05:29
JuanJoFitbit
05-21-2020
22:32
05:29
JuanJoFitbit
my versa randomly no longer vibrates at all. I've reset the device, restarted it, unpaired then repaired, re downloaded the app. Alarms don't work. Notifications come through though. Nothing has worked what else do I do?
06-03-2020 05:28
06-03-2020 05:28
Hi @Tidil05, welcome to our Fitbit Community! I'd like to follow up and help you with your Fitbit Versa since it stopped vibrating. By the way, thank you for troubleshooting this issue before contacting our forums.
I'd like you to try a factory reset. To do so on your device, follow the steps below:
Finally, monitor your Fitbit Versa for the next 24 hours and see if the issue gets fixed.
Keep me posted on the outcome.
