06-10-2019 13:33
06-10-2019 13:33
I run a trail that has the miles marked on it and my Versa is always off by about 100 to 150 yards. How do I correct this? I have called fitbit several times and I don't think the foreign customer service reps understand what I am telling them. All they do is tell me to reset my Versa! I'm getting very frustrated with them!
06-10-2019 14:20
06-10-2019 14:20
Hello @Igoo65 and a warm welcome. I'm happy to give you a user perspective on these distance measurements. If you are running without GPS, then you get a steps x stride length distance. Our running stride varies going up and down hills. Fitbit estimates your stride length based on height and gender. Running mechanics can also throw in a monkey wrench if you have a short stride compared to a longer, loping stride. Tweaking your stride length will help if you run without GPS.
But I am going to guess you are doing GPS connected runs and are frustrated with the marked vs GPS distances. The reality is -- the GPS position is not as pinpoint as we think it is. I read one site that gives a radius of 16ft as the current average smartphone accuracy. When you get a mark, you are somewhere in a circle of about 800 square feet. I look at my maps after I am done. I have been shown to be running through walls, off a cliff, not on the bridge (levitating above a ravine). You get the picture.
I think your distances are within the accuracy of smartphone GPS.
Laurie | Maryland
06-10-2019 14:32
06-10-2019 14:32
Thanks for the response. I guess what bugs me is, that If I use my map my fitness app. It is almost the same distance as the marked trail. It is just a pain to turn the app on and off through my arm carrier.
06-11-2019 03:40
06-11-2019 03:40
@Igoo65 I haven't used map my fitness and am intrigued by the difference in the two measured distances. I am a user, not an engineer -- so I am sitting here with my puzzled face on, trying to understand how two apps using the same sensors get different distances.
I understand why you are frustrated.
Laurie | Maryland
