10-03-2019
18:25
06:16
10-03-2019
18:25
06:16
My versa started a few days ago with message on screen: large red X- requires internet permission, what does this mean? I have synced, statted mew account with no luck...please hell, anybody
10-04-2019 06:23 - edited 10-04-2019 06:25
Hi there @GGivens, welcome to the Community Forums. Thanks for troubleshooting your Versa to fix the red X on the screen. Nice way to go!
Well, this usually happens when you performed a factory reset without before unpairing the device. Usually you should unpair your Versa, forget Bluetooth and perform the factory reset. To solve this issue follow these steps in the order shown:
Please note that when a factory reset is done, all apps installed and the data that has not been synced yet to the Fitbit account will be deleted.
Let me know the outcome, I'll be around.
02-25-2020 21:17
02-25-2020 21:17
My Fitbit versa2 also not started the red xmark is coming on watch please help me out of this problem
Best Answer02-27-2020 10:25
02-27-2020 10:25
Hi there @Suryalatha, welcome to the Community Forums. Thanks for the details provided about the red X mark on your Versa 2.
I was about to create a support case on your behalf, but I've seen you contacted our Support Team after posting here and that they have helped you with this. Please keep an eye on your inbox for updates on your case.
Let me know if there's anything else I may do to help you.
Best Answer02-27-2020 18:17
02-27-2020 18:17
Best Answer02-28-2020 11:57
02-28-2020 11:57
Awesome @Suryalatha! 😉 I'm glad to hear that our Support Team is helping you already.
Please do not hesitate to ping me out if there's anything else I may do to help you.
Best Answer02-28-2020 18:59
02-28-2020 18:59
Best Answer06-18-2020 12:27
06-18-2020 12:27
Thanks! Tried several other suggestions and this is the one that finally worked for us:)
Best Answer09-08-2020 04:51
09-08-2020 04:51
Best Answer04-09-2021 00:45
04-09-2021 00:45
The Factory Reset DOES NOT WORK to fix he RED X, this will only bring it up again. Its actually NOT broken and it's actually NOT complicated BUT the Fitbit SHOULD tell you what to do!
1. Go into your Fitbit App on your phone,
2. Tap Your Face at the top (or where your face is supposed to go, to the left of the word FITBIT), This brings you to the account page,
3. Go to + SET UP A DEVICE (in blue). Then your app will search for your watch and hopefully find it (keep it very close to your phone)
Best Answer06-16-2021 06:42
06-16-2021 06:42
Hi,
mine kicked off differently, first it stopped syncing, then pairing, and my phone couldn’t find it, then it stopped telling time and wouldn’t return to the current time, it lagged by 6 minutes. So i removed it from the account to reconnect it but because my phone couldn’t find it …
so obviously I did a factory reset. But now it has that dreaded x with complete sync.
but as it’s not showing up on my phone, won’t charge and won’t let me do anything at all now, just has the x and my phone is none the wiser.
please help
06-16-2021 06:45
06-16-2021 06:45
But if the x is there, your phone won’t get a signal as it’s not really on? My phone can’t find it all.
09-09-2022 07:29
09-09-2022 07:29
I've tried everything Fitbit has suggested and still get the red x
09-09-2022 07:30
09-09-2022 07:30
Again... I tried all of this and it still doesn't work. I still have the red X
