Versa is showing a temperature sign
Hello,
Purchased the Versa yesterday. The clock face that I chose is supposed to display the weather, however mine is just showing the temperature sign. I checked the weather app, it is working and displaying the weather. How do I get the front face one to display as well. Its partially why I chose this specific clock face.
Thanks in advance!
1 REPLY 1
Kay, I suspect you are using a 3rd party watch face and they typically don't use the Weather App for their data.  You need to contact the Developer or there might be a Settings menu for your watch face where you choose who to use for weather updates. Where your face is shown in Settings, if you scroll all the way down, there should be a "Contact Developer" link and/or a Settings gear icon.
