03-31-2021
09:47
06:16
03-31-2021
09:47
06:16
I have been using the versa for almost 3 years now. This is the second time it happened. It showing 0% battery even after I charged it for more than 1 hour. Resetting the tracker is not working. Is it the battery problem? Or it just died on me now after years of using it..😔
Please advice. Thanks
04-01-2021 06:19 - edited 04-26-2024 08:48
Hi there, @Keyda. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa before reaching out.
Besides the steps you've done so far, I'd recommend performing a factory reset on your Versa. However, before doing so, I suggest removing the Versa from your phone's Bluetooth, then proceed with these steps:
Bear in mind that the factory reset procedure erases stored data, including the stats that were not synced to your Fitbit account. Also, applications installed, music downloaded, alarms, etc.
04-04-2021 04:20
04-04-2021 04:20
Hi,
I have tried follow your instructions. But it doesn't work. The three buttons push is not working. No Fitbit logo appears. Please advice
04-05-2021 03:50 - edited 04-05-2024 13:06
@Keyda I appreciate you had followed the tips and recommendations provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
