04-21-2018 08:31 - edited 04-21-2018 08:47
Versa is the best!
04-21-2018 08:33 - edited 04-21-2018 08:34
Easy to use, consistent visuals for me and very easy to use. Not checked dev docs yet, but more than happy with my Versa and so is my wife with hers.
04-21-2018 08:35
04-21-2018 08:35
Good to hear! I hope you convince your friends and family to purchase one as well. 🙂
04-21-2018 08:37
04-21-2018 08:37
Works just fine for me. A big step ahead from the charge 2. Getting 4/5 stars from amazon over 200 reviews. Everybody is entitled to their own opinion.
04-21-2018 08:41 - edited 04-21-2018 09:19
I like mine too. It's low-key, but high quality. Screen has great resolution, brightness. Notifications and connected GPS work great now also.
Just figured out that the first column in apps (2 of them) activate from the RH buttons on the clock screen. I have "exercise" and "calculator" on mine.
Tried a bunch of the clock faces but am now back on Fitbit's "Simple" one since it best meets my needs, plus they added an option to change the clock color from shocking pink to a more soothing blue. You can't imagine how pleased I am with that. 🙂
For reference, I also own a Blaze, Charge 2, and a Surge. Until I got the Versa I thought the Charge 2 was the best overall design.
04-21-2018 09:26
04-21-2018 09:26
So, you edited your original post. You bored or something?
