01-12-2021
04:56
06:32
01-12-2021
04:56
06:32
Hey community!
Since the Update which included the new zones the Heart rate tracker isn't functioning properly. I'm now achieving the weekly goal of 150 zone minutes in just a few minutes. It's tracking my heart rate way too high.
The reseting didn't help with that.
Do you have any ideas?
Sorry for the worse English.
01-12-2021 06:36 - edited 01-12-2021 12:10
Hello there @Anja_B, welcome to the Community Forums. Thanks for sharing the details about the issue with your Versa and for trying to troubleshoot it before reaching out.
Heart-rate tracking can be affected by several factors including air temperature and device location on your arm For more information, I recommend you to check and How do I track heart rate with my Fitbit device? and What factors can affect my heart-rate reading on my Fitbit device?
If your heart-rate tracker seems inaccurate after taking the recommendations above into consideration, please reply to the following questions:
Look forward to your reply.
01-12-2021 09:33
01-12-2021 09:33
Hey @MarreFitbit!
Thank you for your Tipps!
But unfortunately they didn't solve the issue.
What were you doing when you noticed the problem? If you were exercising, specifically what types of exercise?
The issue occurs during all normal activities like sitting, walking and exercise (yoga).
Were you wearing the Fitbit device particularly tight or loose?
It's not sitting to loose (not wiggling around) but also not to tight.
What was the position of the Fitbit device on your wrist?
The same position as any watch
I really hope you can help me because otherwise I'm very happy with the device!
01-12-2021 12:12 - edited 03-22-2024 16:22
@Anja_B You're welcome! I appreciate you had followed the tips and recommendations provided above.
Since this sounds a bit more serious, I've created a support case on your behalf - you should receive an email from Customer Support at the email you used to register with the Community forums. Note that we may take a bit long to get back to you since due to recent events affecting our operations, support options are limited and wait times are longer than usual.
We hope your issue is solved soon.
09-11-2021 12:41
09-11-2021 12:41
I have the same problem. Today I have walked 3085 steps and have 170 active minutes. I live at 7000’ in Southwest Colorado. My average heart rate is 85, I have 4 minutes peak, 45 minutes cardio and 72 minutes fat burning. My watch is snug above my wrist bone. Is there a fix for this?
