01-30-2019
21:50
08:36
MarcoGFitbit
01-30-2019
21:50
08:36
MarcoGFitbit
Low battery. I’ve tried so many solutions but nothing has worked for me. Unplug and plug back in the extension cord, tried a different usb cube, tried a different wall plug in, Restarted it multiple times, cleaned the charger and the back of versa twice. What else is there?
01-30-2019 22:09 - edited 02-12-2019 21:43
@Shelbystein92 Try rubbing charging port with alcohol and plugging to USB port on your computer for charging. If this does not help, you might need to reach out to Customer Support as this could be a faulty charger issue.
01-30-2019 22:58
01-30-2019 22:58
01-31-2019 00:18
01-31-2019 00:18
@Shelbystein92 Does your Versa have any battery left? How much? Does it still sync? Do sensor lights blink?
01-31-2019 06:36
01-31-2019 06:36
01-31-2019 07:55
01-31-2019 07:55
Might try another charging station. I thought my Versa would not charge, but luckily my wife has one too, so I tried her charger and it worked. So clearly my charger failed not the Versa.
01-31-2019 08:53
01-31-2019 08:53
01-31-2019 19:39
01-31-2019 19:39
@Shelbystein92 Do you have access to another charging dock?
01-31-2019 20:01
01-31-2019 20:01
01-31-2019 20:08
01-31-2019 20:08
@Shelbystein92 I see. I wish you had contacted Customer Support instead. They would have shipped it for free. That's usually what they do in this kind of situations. So I heard.
01-31-2019 20:42
01-31-2019 20:42
01-31-2019 20:45
01-31-2019 20:45
@Shelbystein92 you can use it to test it I guess but I would still reach out to Fitbit for the original one.
01-31-2019 20:48
01-31-2019 20:48
01-31-2019 20:52
01-31-2019 20:52
@Shelbystein92 Yes, as your Versa is obviously not working and under warranty. It's usually what they try first. I hope it's just a charger. It would be a simple solution. Good luck.
01-31-2019 21:01
01-31-2019 21:01
01-31-2019 21:09
01-31-2019 21:09
@Shelbystein92 ah I see! Good luck then! 😊
02-05-2019 09:36
02-05-2019 09:36
Hello @Shelbystein92 and @BellevueDad, have a warm welcome to the Fiotbit Community, it's great to have you on board. It's nice to see you too @Marrrmaduke, thanks for all your help.
@Shelbystein92 and @BellevueDad, I appreciate you have shared your experience with us. @BellevueDad, thanks for letting us know that changing charging cables worked for you.
@Shelbystein92, thanks for letting us know you've already contacted our Support Team, if the charging cable you just purchased does not work with your Versa, it's possible the watch is the problem and as you already might need to return it so our team can continue assisting you.
Thanks for your patience and understanding, keep us updated!
07-28-2019 21:01
07-28-2019 21:01
Had a similar problem with mine. Forgot to put it on the charger and completely died, when I did set it on the charger, says it's at 0%.. after about 5 hrs still showed 0%!! Tried cleaning charger and watch with alcohol but still nothing. Don't know what to do at this point.
09-20-2022 14:52
09-20-2022 14:52
I am having same issue. Bought new chargers but still nothing
