09-04-2020 00:49
09-04-2020 00:49
My versa won't charge or reset. I have left the device on charge overnight and tried all of the suggested steps to reset but nothing happens. Strangely I had it working yesterday after months of trying to get it working but it seems to have crashed again!
I am on a Samsung mobile device.
Can anyone help?
09-04-2020 09:08
09-04-2020 09:08
Hi @lil_leah220
I'm sorry to hear you are having a problem with your Versa. Have you tried doing a factory reset?
09-04-2020 09:32
09-04-2020 09:32
I agree with MarciM, a Factory Reset usually fixes around 95% of issues.
If you don't know how to do it just let me know and I'll post a talk through for you.
Hope this helps.
09-04-2020 09:35
09-04-2020 09:35
Is that holding the back button and bottom button down? If so, I have tried that.
09-04-2020 09:48
09-04-2020 09:48
Hi @lil_leah220
That is a restart. When you have done the restart, does the screen go black and then the Fitbit logo appears? It can take 10+ second for it restart.
A factory resent is the next step and you do that by:
I hope that helps!
09-04-2020 10:00
09-04-2020 10:00
Hi Marci,
Nothing happens (no fitbit logo etc) when I do the reset. Any ideas?
09-08-2020 15:17
09-08-2020 15:17
Hi Marci,
I'm unsure how to do the factory reset if my fitbit won't turn on. Do you have any suggestions?
09-09-2020 07:52
09-09-2020 07:52
Hi @lil_leah220
I don't believe there is anything further we can do on the forum to help you, so your next step is to contact Customer Support.
