Versa isn't holding a charge
It seems my battery life is very short. I'll charge it in the morning when I'm getting ready for work and by the next morning it's already down to 63% oor less. Usually 3 days is all it lasts if I push it. I do not have any extra apps installed, nor alarms. I do have quick view on because it's something I need regularly. What else do you suggest please?
2 REPLIES 2
Hi, see this article regarding your battery and improving the life of it. Click the link and click on Versa.
It's great to see you here @Talllgirl and @SunsetRunner thanks for the input.
I was able to see here that our friend @SunsetRunner provided some instructions in order to fix this battery issue. Was this the answer you were looking for? If it was, I recommend marking the answer given as a solution. By doing this, other users with the same inquiry will be able to find a faster response.
Now if your inquiry/issue wasn’t resolved, let me know and I will be glad to help you out. Smiley Wink
