06-22-2021
18:19
17:03
06-22-2021
18:19
17:03
My heart rate is not showing up on my watch? Why? My steps still are & the time! What can I do to fix this?
06-25-2021 17:03 - edited 06-30-2021 09:26
Hi there, @Cburgy. Welcome to the Community Forums.
As a first approach, I'd like you to perform the following steps below for this situation:
I've moved your post to the Other Versa Smartwatches board for organization purposes.
Hope this helps.
06-26-2021 08:52
06-26-2021 08:52
Hi MarreFitbit,
I am having a slightly different issue. My heart rate monitor is working - I can see the green light on the back, although not the red one. Two days ago I stopped getting info on breathing rate and HRV at night. The only difference is that I turned off the background app refresh for fitbit under settings on my iphone because the app was draining my power quickly. I have turned that back on and will check again tomorrow morning. Everything else seems to have been working fine. Also, I have premium. Any thoughts?
06-26-2021 11:12
06-26-2021 11:12
Hi there, @Sally203. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your watch before reaching out.
Take into consideration the following requirements to see your health metrics data:
Also, keep in mind that several factors can affect your breathing rate, including age, sex, weight, lung and heart conditions, anxiety, and fever. For more information, see How do I track breathing rate in the Fitbit app?
Regarding the battery issue, please try updating your Fitbit app to version 3.43 or later. Updating your Fitbit app should fixe the issue with your Fitbit watch's battery life. To do so, see How do I update the Fitbit app?
Hope this helps.
06-26-2021 19:59
06-26-2021 19:59
Thanks Marre. I have minded all the suggestions. Tonight we will see if anything changes now that I have turned the background app refresh thing back on. If it does not resolve the issue, please let me know what may be the next steps? Again, the response you sent was not anything I had not already tried. Might this be a problem with an iphone update? I have had things reported just fine for months.
Thanks
06-27-2021 05:48
06-27-2021 05:48
Again today no breathing rate data or heart rate variability data. Everything else is fine. Please advise. Thanks.
06-28-2021 05:28
06-28-2021 05:28
I have had no breathing rate or HRV on my Versa 3 since June 24th. Is Fitbit working on a fix for this? I've seen other postings with the same complaint.
06-28-2021 05:51
06-28-2021 05:51
Hi @Paddlegirl, I had a live chat with support yesterday and they said they are aware and are working on a fix. This morning, I noted a further change. I got simplified sleep stats in addition to the absence of breathing and heart rate variability data even though I slept for over 7 hours. Let’s hope this means that they are trying things and this is a short term thing.
06-28-2021 10:09
06-28-2021 10:09
Same here! Theres a different thread going with this issue and we are all
dealing with it iPhone and Android alike!!
12-09-2022 21:05
12-09-2022 21:05
this did not work for me i am having the same issue ive done all of the trouble shooting steps including factory resetting. Nothing seems to be working to turn the sensor back on please help.
01-27-2023 05:47
01-27-2023 05:47
same here. The lights at the bottom won’t turn on again and the heart rate isn’t working either. Someone please tell me what to do
