11-08-2018
07:00
09:21
AlejandraFitbit
11-08-2018
07:00
09:21
AlejandraFitbit
I'm really annoyed with my Versa! Its a great hassle to get it to sync to the app! I have a Samsung Galaxy S8+. I never had a problem with my Flex 2 and Charge 2. But, since I got my Versa, the app won't work right. I have to log out or restart my phone or close and reopen my Bluetooth, and even reset my Versa to maybe get it to sync! I did all of the above last week and it worked fine until Sunday. But now, it hasn't sync since Sunday evening. And, I can't get it ton sync. Can someone help me? I'm almost to the point of getting rid of Fitbit and go with an other brand.
11-19-2018 14:46
11-19-2018 14:46
I couldn't have said it better. The root cause of this issue needs to be identified and solved. My wife and I used the Charge and Alta products with absolutely no synching issues. We've had our Versa watches for several months and have constant synching issues. We follow the same usage patterns as we did with our previous devices. As a user we thought getting a new 'better' device would bring an enhanced and waterproof experience - we were wrong! We both use an iPhone 8. Can Fitbit please step up and admit there is an issue and fix it. This is wasting your customers time. Thanks.
11-19-2018 15:34
11-19-2018 15:34
11-19-2018 15:57
11-19-2018 15:57
I have an iPhone 8
11-19-2018 18:18
11-19-2018 18:18
@Deathwishvixen I'm assuming app version is 2.82. try downgrading to 2.81 or better to 2.74. you will have to sideload it.
11-20-2018 05:30
11-20-2018 05:30
I hate to downgrade because when I get new updates I will always update. Thanks anyhow. Can Fitbit please respond?
11-20-2018 05:31
11-20-2018 05:31
Hi Marrrmaduke
iphone XS, iOS 12.1
fitbit app 2.83
versa version from settings on watch 32.12.19
thx.
11-20-2018 06:16
11-20-2018 06:16
I have 12.1 and 2.83 but I have 32.10.15 versa firmware not 32.12.19. Is that any issue? How do I know if I have to upgrade my firmware and how do I do it? Thanks
11-20-2018 13:38
11-20-2018 13:38
@Rafter10201 You're on iPhone. You cannot downgrade. I would suggest setting up everything from scratch. Deleting versa from your Fitbit account in Fitbit mobile app, uninstalling the app from your phone, unpairing versa from your phone, rebooting your phone, performing factory reset of your versa, and setting it up again from scratch.
11-20-2018 13:42 - edited 11-20-2018 13:43
@SunsetRunner wrote:Hi Marrrmaduke
iphone XS, iOS 12.1
fitbit app 2.83
thx.
If you haven't tried that already, try forgetting versa from your Bluetooth settings, followed by reboot of iPhone and reboot of Versa. When you try to sync manually within the Fitbit mobile app, it will ask you for pairing. Grant it. If you have already tried that, please perform factory reset as described in my post here.
11-21-2018 06:54 - edited 11-21-2018 07:06
Hello everyone, I hope you're doing well. It's nice to see you @Marrrmaduke, thanks for all your help.
I appreciate some of you have come back and let us know the troubleshooting steps you've tried in hopes to resolve this issue. At this moment, if you haven't done it yet, please update your Versa to the new firmware update.
Please note that this update has only been released to a small group of Fitbit Ionic and Fitbit Versa users. If you have not yet received an update notification and wish to force the update, you can give the watch a FACTORY RESET and then follow steps 1 - 4 below. Please make sure you sync the watch before performing the reset so that all your current data transfer over. Factory resetting your device clears all data from the watch including music, Fitbit Pay information, and apps. Historical Fitbit data will still be available in the Fitbit App.
If you run into trouble updating your Versa, please follow these steps:
I hope this can be helpful, if after updating your Versa, the watch is still not syncing correctly, please let us know.
11-21-2018 11:26
11-21-2018 11:26
Really disappointed in my versa.
I wanted to keep my charge 2 on the app but was told I couldn't so that was uninstalled when I installed the versa.
I have followed everything including your instructions on this tread and the versa still won't sync. I spend more time messing with the stupid thing than exercising.
It synced at 10.19 this morning it is now 19.22 and it won't sync. When I try to force it it just says sync scheduled but nothing happens. I bought it because I wanted a bigger display so I don't have to wear a watch but if it doesn't work soon and permanently it is going back.
If your Versa is still not syncing, please reply to me with the following information:
Thanks for your patience and understanding, we hope to hear from you soon.
11-21-2018 12:40
11-21-2018 12:40
@caz320ml it's the problem with the app versions above 2.81. you should be able to add both trackers with Fitbit mobile app v. 2.81 or lower. Fitbit is working to resolve this issue. In the meantime, uninstall current version of the app and sideload 2.81. you can find it on the internet.
11-22-2018 04:45
11-22-2018 04:45
Thanks everyone. I have been watching my two sick grandchildren. I haven’t had the time to look through and decide what to do next. When I can I will let you know ... thanks again
11-26-2018 14:43
11-26-2018 14:43
I had a problem syncing with my Galaxy Note 8.
I had updated the firmware to the latest and no amount of pairing or re-pairing would work.
I finally did a restart of the Versa by holding down the Left and Bottom Right buttons until the Fitbit Logo appeared. When the Versa restarted, everything was fine.
Note: I had previously tried doing a restart, but when the screen blinked, I thought it had restarted, when actually it had not. You have to hold the buttons for about 10 seconds until you see the Fitbit logo appear.
11-26-2018 21:16
11-26-2018 21:16
I'm Unable to downgrade, but it randomly starting syncing perfectly after the screen broke
11-27-2018 07:23
11-27-2018 07:23
I appreciate some of you have come back and let us know your Versa is now syncing, I'm very glad. For those of you who are using an Android device and are still experiencing issues, I would like to suggest you to check the following:
Depending your phone, these tips might make syncing easier:
Now, I understand you concern about your some of your phones are not listed as compatible devices, please note that many Android phones have all the hardware requirements to be a supported device but are currently not on our list of supported devices. This means that we have not tested it for compatibility and added it to the list yet. For the time being, we don't have an specific date or time-frame of when is going they will be listed as compatible.
While these devices has all the specifications to be compatible and are currently working with the Fitbit app, it's possible to come across some issues along the way. I appreciate your understanding while we work to improve this experience, if there's anything else I can do for you, please feel free to reply.
11-27-2018 13:59
11-27-2018 13:59
11-27-2018 14:07
11-27-2018 14:07
11-27-2018 17:29
11-27-2018 17:29
I am about to give up on Fitbit and share my frustration on every social platform I can find. I had an Alta that simply fell apart after maybe 15 months of use. I could accept that I might have been maybe too active, maybe somehow hit it against something, but I was 68 when that happened. So nevertheless, I bought into the hype on the Versa and my wife got me one for my 69th birthday, 6 months ago. I could have gone Apple but didn't need all that functionality, and liked the advertised Versa 5 day battery life. That said, after maybe 3 months, the battery life dropped to maybe 2 days max. And, despite all the help articles I have not been able to sync the Versa to the phone app since Oct 12. So now I have a "watch" that pretty much only counts my steps and maybe measures my pulse and will give me an alarm if I set one. Oh? I forgot to mention that it doesn't keep good time if it CAN'T SYNC! I'm presently 4 minutes slow so I use my phone for real time. So I'm ready to advertise my frustration with Fitbit as widely as I can and they can't buy word of mouth advertising like that for any price.
11-28-2018 02:06
11-28-2018 02:06
I know exactly how you feel. For my versa to sync I have to switch it off, turn off bluetooth, un pair it and then switch it back on. Half the time it won't then connect with the phone.
