02-20-2023
18:58
12:53
LizzyFitbit
02-20-2023
18:58
12:53
LizzyFitbit
I still have problems with sleep getting recorded. Notification will state: you need to wear your Fit Bit at night...
I do wear my FB Versa Premium on my left wrist every night, and sometimes it will not track sleep...
Also, tracking is not working if you get up at night or awake at night...it should resume tracking when you go back to sleep.
Moderator Edit: Clarified subject and updated label
02-28-2023
12:59
13:04
02-28-2023
12:59
13:04
Hi there, @Cece71.
I've moved your post to the Other Versa Smartwatches board to keep the forums organized. Thanks for the details provided. While this is odd, may I know if you're sleeping for more than 1 hour? I'm asking this as when you haven't moved for about an hour, your Versa will start tracking your sleep. In the case of sleep stages, your watch requires 3 hours of sleep data.
That being said, please make sure your Versa is syncing with the Fitbit app and give a try to the following steps:
03-01-2023 11:23
03-01-2023 11:23
To Admin: yes, I sleep for about 3 hours and wake up for about 45 min. Then go back to sleep.
03-17-2023
13:21
13:04
03-17-2023
13:21
13:04
@Cece71 It's good to see you around.
Thanks for getting back with those details. I understand you're sleeping more than 1 hour, but may I know if you tried the rest of the steps described above? If not, please give them a try, wear your Versa to sleep and monitor its behavior in the next few days.
