11-25-2018
15:20
05:01
AlejandraFitbit
11-25-2018
15:20
05:01
AlejandraFitbit
My Fitbit was charged and randomly turned off today. I have tried resetting it and charging it, it will not do anything. Not sure what else to try. This is already a replacement and is approx 5 months old.
Best Answer11-25-2018 15:44
11-25-2018 15:44
Restart it several times. Also try a factory reset. If that doesnt help you will need to contact Support (link in my signature)
FACTORY RESET USING BUTTONS
On the watch, hold all three buttons for about twelve seconds. This triggers the 2-button hardware reboot after about eight seconds.
- When the Fitbit logo appears, then disappears, release the bottom right button, then continue holding the left and top right buttons until you feel a strong vibration. This indicates the factory reset was initiated.
- This process may take several seconds, and eventually, the Fitbit logo appears and the device boots and displays go to Fitbit.com/setup.
- If you fail to release the bottom right button in time, or otherwise don't follow the procedure precisely, the Fitbit logo reappears quickly and boots without factory reset.
If the device turns on, please go back to the Fitbit app and setup your device back to your account with these steps. Make sure your watch is plugged into a wall plug or a computer, next to the router and that there are no other trackers or devices with Bluetooth on nearby when setting up. Please log into your account, go to account on the upper right corner, there look for "setup a device" and tap on it. Follow the instructions on the screen and let the watch charge for 2 hours.
Helen | Western Australia
11-26-2018
05:01
06:26
11-26-2018
05:01
06:26
It's great to see you here @crystalann77 and @NellyG thanks for the input.
I appreciate all the efforts in trying to fix this issue and would like to know if the instructions provided by our friend worked? Were you able to turn on your watch?
Hope to hear from you soon. ![]()
