Versa just won't turn on
My Fitbit just stopped working out of the blue. Tried charging and switch on. Nothing happened? What should I do?
25 REPLIES 25
Have you tried restarting it by pressing and holding the left button and bottom right button together for 15 secs (until you see the fitbit logo)?
Community Council Member
Nathan | UK
Looking to get more sleep? Join the conversation on the Sleep better forum.
It still doesnt work?
Hi mine is doing the same.
Hey guys! @HSel and @Superman1506, welcome to the Community!
Did you try to restart your Versa as @N8teGee previously suggested you? If you haven't, please give it a try and also, please let me know if it is charging when you plug it into the charging cable.
I'll be around!
Heydy | Community Moderator, Fitbit
Hi I have pressed the left hand button and the bottom right hand button together but no Fitbit icon comes up only a whitish screen with a few horizontal lines in the middle which disappear after about 10 seconds.
Mine just went black too. Tried the reset but nothing!
The charger does nothing either.
Time to contact Support, then.
one cruise ship at a time!
Hi, I did try to restart it but it didnt work. I even charged it but nothing came on the screen. Just black screen
Mine just did the same thing. Any luck with a fix?
Seems to be a worldwide issue and a huge problem because mine has been dead for 3 months.. I contacted fit bit and when I told them where I purchased it they will no longer help or assist me..
I've noticed the same thing and just sent a message to support. It won't turn on and restarting doesn't do anything.
I contacted support, via online chat. They could not get it to turn on either. Since mine is under warranty they are sending a replacement.
Yea I had to do the same thing. Hopefully this one lasts longer than the first one
Felicia
Sent from my iPhone, please excuse any errors.
I do have warranty how do I get a replacement?
Contact customer service and let them know what is going on with your watch. Where did you purchase it?
Felicia
Hi I contacted the helpline and after a conversation about my query they asked me to send a photo of my Versa screen after I had tried to reset it. They are now sending me a replacement which I hope will last longer than my old one which was 5 months old.
My screen has also went black. I have tried restarting it and nothing shows up I have tried charging it but nothing works there either... what do I need to do? I really enjoyed this watch and would like to get this fixed if possible.
Mine lasted about that long and I hope my replacement lasts longer than 4-5 months.
Felicia
