11-24-2023
12:16
03:52
11-24-2023
12:16
03:52
My Fitbit Versa keeps going back to the clock face when I swipe up to see my steps and other info. I did restart and it’s still not working properly.
11-25-2023 03:59
11-25-2023 03:59
Hi there, @rvogenitz. Thanks for stopping by in the Fitbit Community Forums. I'm sorry to hear that your Versa screen keeps going back to the clock face when you swipe up. I appreciate you've taken the time to troubleshoot this issue already, I'll be glad to help!
To better assist you, please make sure you've restarted your Fitbit device as suggested here How do I restart my Fitbit device?. If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Hope that helps.
Best Answer11-25-2023 18:35
11-25-2023 18:35
Having the exact same issue. Scroll up shows logo and immediately returns you to clock face. I have tried multiple restarts and have changed to a few different clock faces too. Nothing works ?
11-25-2023 18:49
11-25-2023 18:49
I gave up on it. I’m using something different now.
Best Answer11-25-2023 23:35
11-25-2023 23:35
Having the same issue. The solution you have provided did not fix the problem.
Best Answer11-25-2023 23:51
11-25-2023 23:51
Ditto with my versa2
Best Answer11-26-2023 15:17
11-26-2023 15:17
Hi…Same problem with my Versa. Tried all your suggestions and nothing worked.
Best Answer11-27-2023 18:14
11-27-2023 18:14
I was having this same issue and I removed my versa 2 from my account and added it back in. It seemed to fix the issue.
11-28-2023 15:34
11-28-2023 15:34
