09-06-2018
15:59
10:06
HeydyF
09-06-2018
15:59
10:06
HeydyF
I have been using a Fitbit Versa with an iPhone SE for a ferw weeks now. I use the exercise app on the watch to track "walk" exercise events.
When I started using this "walk" app, it would record map data along with heart rate, speed, etc.
Starting September 4, the map data no longer appears on the Fitbit app of the iPhone SE. The map data no longer appears on the fitbit.com website either.
Anyone else seeing this problem?
09-15-2018 11:07
09-15-2018 11:07
09-07-2018 10:06
09-07-2018 10:06
Hey @SunsetRunner, it is great to see you around more often! Are the steps, distance, heart rate and calories from your walks still logging? So just the map is missing or anything is been logged? If just the map is missing, maybe this is more related with the GPS between your Versa and your iPhone. So I suggest you to take a look at the troubleshooting in this help article: Why isn't GPS working on my Fitbit device?
Let me know how it goes!
09-15-2018 11:07
09-15-2018 11:07
09-30-2020 23:03
09-30-2020 23:03
I've been using Versa 2 for months to map walks in conjunction with an Android phone. The Versa has ALWAYS indicated a connection by vibrating, and this has always occurred several seconds to most of a minute after the Walk was selected AND Start was selected. The maps were always generated without any awkward extra workaround like waiting to press the strat button.. Until September 22nd. Since then, no walk has generated a Fitbit map. There has been no GPS Lost warning, and mileages seem plausible. But the elevation gain on the Versa is always 1374 ft, which is always wrong. So a new and consistent failure started at a known time. I just don't know how to fix it.
10-10-2020 15:59
10-10-2020 15:59
This is happening to me too. The last 2 walks I have done have no map.
Any one know of a solution yet?
10-27-2020 10:54
10-27-2020 10:54
Same here - my maps stopped consistently appearing in mid-September.
11-21-2020 14:46
11-21-2020 14:46
Yup, mine stopped working today. I'm using Charge2 on Android 10. Map worked perfectly yesterday and then today's run tracked everything perfectly but no map. It also didn't sync to Strava automatically like it used to and I can't see a way to force that anymore.
01-15-2021 12:28
01-15-2021 12:28
Same here. Fitbit off by over a mile less than my Samsung Health app. registers. No map. Shows connecting throughout the walk. GPS signal weak. Solution?
01-15-2021 14:41
01-15-2021 14:41
