Versa lite battery life suddenly hugely reduced
My versa lite is less than 5 months old and over the last 2 weeks the battery life has suddenly dropped from 4-5 days to under 2. I go to the gym several times a week and use the various sports settings to track my progress and have the watch synced to an iPad. Until 2 weeks ago everything was fine. I had a charge 2 before this for nearly 2 years and while I wasn’t using the gym or swimming with it it did still hold its charge, I only replaced it because I’d cracked the screen
1 REPLY 1
@AB63 Welcome! Thanks for being part of our Community! Sorry for the delay in my reply.
Let me help you with your Versa lite battery draining quickly. Try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. After this, restart your device and see how it behaves. You can follow these instructions to help improve the battery life.
Let me know how it goes.
Alvaro | Community Moderator
