08-28-2022 02:01
08-28-2022 02:01
Hi there, my fitbit replacement is not working and it is under a year old, I am really gutted because I use it every day.
Best Answer08-28-2022 16:24
08-28-2022 16:24
Hello again @loups
You would need to contact Fitbit Customer Service to discuss your warranty options with them. Here are ways you can contact them:
USA: call (877) 623-4997
UK: call 0800 069 8505
INDIA: call 000 800 050 1057
IRELAND: call 01 691 7502 (country prefix: +353)
More information can be found here: https://myhelp.fitbit.com/s/support?language=en_US
😃 I hope this answers your question. Please let me know
Best Answer08-28-2022 11:25
08-28-2022 11:25
Hello @loups
If your having syncing issues try turning your Bluetooth off, restart your phone then turn Bluetooth on again. Now try to sync your Versa Lite. If your still not syncing you can try restarting your Versa Lite. Just press down and hold the button on the Versa lite until you see the Fitbit Logo then release the button. You should feel the Fitbit vibrate telling you the restart is finished. Now again try to sync your Tracker.
😉 Hopefully this helps and resolves the syncing issue. Please let me know how it goes
Best Answer08-28-2022 16:12
08-28-2022 16:12
Best Answer08-28-2022 16:15
08-28-2022 16:15
Thanks but I have tried all this several times, even reset back to factory settings still not connecting unfortunately. Ideally I think I need a replacement.
08-28-2022 16:24
Hello again @loups
Best Answer08-28-2022 16:30
08-28-2022 16:30
08-28-2022 16:46 - edited 08-29-2022 05:01
Hello again @loups
I hope Fitbit Customer Service gets everything sorted out for you. But I did want to mention that you can try one more thing if you want. It’s certainly worth a shot. You said you performed a factory reset. You can set up your Versa lite again as a new device. It will also address your syncing issue doing this too. It might prevent the hassle of trying to get a replacement. If your interested here’s how:
Setting up your Versa lite as a new device will not make you lose any data as your data is held on the Fitbit Servers. You will however lose all data that occurred after your last successful sync.
To set your Versa lite up again as a new device please follow these steps closely:
😉Maybe this might do the trick. Again it’s certainly worth a shot
Best Answer08-29-2022 01:49
08-29-2022 01:49
Yes I have done this also and it’s not connecting to be able to finish off the last step. It’s a versa lite also is this called a versa 2 then?
louisa
Best Answer08-29-2022 05:04
08-29-2022 05:04
No @loups a Versa Lite and Versa 2 are not the same. I did notice I referred to yours as a Versa 2 a few times but the steps are still the same. I apologize. I hope you can get it all sorted out with Fitbit Customer Service. 😉
Best Answer08-29-2022 05:35
08-29-2022 05:35
Ok no worries so do I, will be disappointed if they don’t help as it’s under a year old the replacement.
thank you
