Versa lite screen was unresponsive - now it is Bricked
So the touchscreen was unresponsive, so as mentioned on these forums did the following
  1. Reboot by holding down button - screen still unresponsive
  2. Factory Reset
  3. Added as a new device in App
  4. App suggested an update was required so Started update
  5. Update froze - was at 1% for an hour
  6. Cancelled update
  7. Rebooted watch
  8. Screen display "Data not cleared - Sync and try again"
  9. Repeated a factory reset and a reboot - just continues to show message on step #8
I cannot do anything to get it out of this "Data not cleared" mode tried multiple reboots, factory resets just goes back to this same
Any suggestions?
1 REPLY 1
So guess what,
I managed to fix the Versa Lite with the computer, or at least it's working now.( Wasn't easy at all) The problem is that now it has the same problems it had after the last update, after I did the factory reset. So it's on, but it's rebutting along the day to many times, sometimes the touch screen doesn't work and I have to reset it and other times it's working just fine. the worst part is when I'm sleeping and it suddenly restart by itself and wakes me up.  So I don't know what to do now!  I read there's going to be a new  update, is this going to be fix or do I have to change my Fitbit ?
