08-03-2019 21:02
08-03-2019 21:02
Hi,
I recently purchased my versa lite and have loved it until today at work when it would not sync to the app. Once I got home this evening I began trouble shooting. I re-downloaded the app, restarted the versa, turned Bluetooth on/off, restarted the phone, and updated the phones OS. I have an iPhone 7 Plus which is not fully updated to IOS 12.4. Nothing worked.
I unfortunately made the mistake of doing a factory reset on the versa after going through the settings on the versa and now it is unusable as it needs to be re-set up but won’t connect to Bluetooth.
HELP! I feel like I’ve wasted $200!
08-03-2019 21:03
08-03-2019 21:03
my phone IS fully updated to IOS 12.4
08-03-2019 21:05
08-03-2019 21:05
I also disconnected all other Bluetooth devices and made sure it wasn’t connected to Bluetooth on my iPad.
08-03-2019 21:08
08-03-2019 21:08
Is your phone on the supported list?
Some things will work while others will not. I'm sure it will get add at some point if its not there
Wendy | CA | Moto G6 Android
08-03-2019 21:12
08-03-2019 21:12
It is, it worked just fine for three days.
