03-13-2020 09:39
03-13-2020 09:39
Today my versa says I have done 4.79 miles so far but the circle is not closed. But my miles activity goal is set as 4.5 miles so the circle should be closed. I've tried changing the activity goal and I've tried uninstalling the app.
Any ideas - I'm a bit obsessed about all my circles closing every day!
03-13-2020 21:32
03-13-2020 21:32
What circle are you referring too @egraves81
Is this the circle of the GPS map. I can't think of any circle with your tracker?
03-22-2020 10:16
03-22-2020 10:16
Mine is doing this too. Have you had any luck figuring out how to fix it? My goal is 4 miles a day and I did 4.57 and it's like 3/4 the way closed
03-22-2020 12:07
03-22-2020 12:07
I am seeing the issue.
Where you to find a fix for this?
03-22-2020 12:09
03-22-2020 12:09
My goal is 5miles
You can see here I have done 6.99miles but the circle is not closed.
03-22-2020 12:17
03-22-2020 12:17
@egraves81 @Marslynn17 @Maliska You are describing an app problem, not a Versa device problem.
What type of phone do you use? Android or iPhone? I would like to move this topic to the appropriate forum so you can get the help you need.
Laurie | Maryland, USA
03-22-2020 12:23 - edited 03-22-2020 12:51
I am using an Android.
As an added note the circle icon on my Fitbit screen has the same issue.
Thank you,
Kind Regards
03-22-2020 12:55
03-22-2020 12:55
I am using an android.
03-22-2020 13:27
03-22-2020 13:27
@Maliska wrote:I am using an Android.
Thank you,
Kind Regards
If this is happening on the app screen AND the device itself, then I won't move this whole thread. This sounds like a new bug and the correct information needs to be reported to the engineers.
All users, be patient. This could take some time to fix.
03-22-2020 13:31
03-22-2020 13:31
Yes the is a problem showing on the screen of my app. I am an android user. Thanks
03-22-2020 13:37
03-22-2020 13:37
When viewing at fitbit.com is the circle the same?
03-22-2020 13:40
03-22-2020 13:40
Yes the same problem occurs.....for yesterday my target setting was 4 miles. The circle on the link above is showing 4.6 miles but the circle is not closed. Thanks
03-22-2020 13:52
03-22-2020 13:55 - edited 03-22-2020 14:06
Yeah mine is like this on my Fitbit itself too
03-23-2020 14:10
03-23-2020 14:10
@egraves81 @Maliska @Marslynn17 I reported this as a possible new bug. Note the large pink banner at the top of the page. The pandemic has affected Support and responses. Don't expect a quick resolution.
03-23-2020 14:49
04-02-2020 22:33
04-02-2020 22:33
Same problem here. Android w/ Versa 2. Watch no longer buzzes when I hit 5 miles either. Note that circle will close at 8.05 miles--8.05 is the number of km in 5 miles. Coincidence? I think not!
Problem occurred with app update in March.
04-06-2020 09:40
04-06-2020 09:40
Hi everyone!
I was wondering if this problem with the distance tile not closing was still happening in the Fitbit for Android app? We released version 3.18 last week. Please make sure you update if you haven't yet and let me know if it's still happening.
04-06-2020 10:18
04-06-2020 10:18
I'm on 3.18. Still have the problem.
Temporary workaround: if your main goal is set to distance (in miles), multiply your activity goal by 0.621 and use that. For example, my 5-mile goal is entered as 3.11 miles. Circle closes, watch buzzes, and I get the star at 5.01 miles (close enough). Note that the bar graph page with day-by-day doesn't display correctly with this workaround--shows the goal and stars based on 3.11 miles.
04-06-2020 10:24
04-06-2020 10:24
I am on version 3.18 and it is still happening. My miles goal is set to 4 miles. Yesterday I did 4.89 miles but the circle is not closed.
Thanks for looking into this.
