12-27-2018 14:54
12-27-2018 14:54
I keep having issues with memory and it lost the sync with my phone what do I do?
12-27-2018 15:36
12-27-2018 15:36
Hi, which phone are you using?
12-27-2018 16:04
12-27-2018 16:04
iPhone x
12-27-2018 16:08
12-27-2018 16:08
Hi, your phone is on the supported list by Fitbit. Would you be so kind as to elaborate more about your problems?
12-27-2018 16:21
12-27-2018 16:21
It doesn’t connnect to the phone with the internet. Also how far I’ve walked on the watch
it says I walked 5000 steps let’s say the phone says nothing doesn’t say I have any miles since it doesn’t pop up. I know resetting to factory settings will fix since I tried that after everything but for the longest time it distance steps heart beat were not shown or an option for the Fitbit app
12-27-2018 16:26
12-27-2018 16:26
Hi, so when I understand you well, you're having WiFi problems, is that correct?
