03-02-2019 07:44
03-02-2019 07:44
Can anyone tell me if I can download music onto my versa from my iTunes library and if I can how do I do it?? Thanks
Best Answer03-02-2019 07:57
03-02-2019 07:57
If your library is on a PC you download the Fitbit connect program and as long as your PC and watch are on the same network, it will search for playlists (not songs) and you can select which ones you want transferred to the watch. It takes a while, but worked pretty well.
Best Answer03-02-2019 10:48
03-02-2019 10:48
