Versa no longer allows me to log exercise
The “+” sign next to exercise in my dashboard has disappeared. There is no longer any way that I can find to log exercise not detected by my Versa (like a yoga practice)
3 REPLIES 3
Hello @Ardenne and a warm welcome.  What type of phone do you use?  That will help with this issue that seems to be an app issue.  That said, yoga is one of the exercises that can be put on the Exercise Shortcuts for the Exercise app that is on the Versa itself.  From your app dashboard tap on your profile picture > Versa > scroll down to Exercise Shortcuts > Edit > remove an exercise that you don't use.  The + Exercise Shortcut can be tapped.  Add yoga.  When your tracker syncs, it will be on your Exercise App.  So much easier than starting/stopping on the app.
Laurie | Maryland
thank you for the reply! I use an iPhone 7. It’s odd because this manual log exercise (the + sign next to exercise on the dashboard) worked fine a day or two ago. Today the + sign is gone with the functionality.
I have the same problem on my iPhone X
