05-14-2020
17:44
11:08
05-14-2020
17:44
11:08
As of a few days ago, my versa sopped tracking bike rides correctly. It shows that its connected to my phone for GPS and it looks like its working, but when I check the log afterwards, it either shows no distance travelled or it will show just a straight line from the start to finish, but not the actual route.
Walking however works perfectly fine.
I tried restarting it, but that didn't help. I haven't done a factory reset yet, but kind of want to avoid going through that hassle if possible.
I have the latest firmware and the Versa 1 and an iPhone 11 Pro with the latest iOS.
05-14-2020 20:16
05-14-2020 20:16
I would look into the position of the phone whole riding?
It looks as if bluetooth is losing connection.
Best Answer05-15-2020 03:29
05-15-2020 03:29
Best Answer05-15-2020 12:57
05-15-2020 12:57
I have this problem too, I shows watch connected but when stopped 5 mins later it just shows connecting?
Have tryed every setting still no luck. If I use Strava on the phone it works fine tracking my ride. Not very impressive on a brand new versa.
05-15-2020 13:19
05-15-2020 13:19
Yep exactly! I'm also using Strava as a backup, although when it DID work I liked the Fitbit tracking much more because heart rate was integrated.
Best Answer05-15-2020 15:10
05-15-2020 15:10
I am having the same issue and it started after the latest update. Today I did a 10 mile bike ride my fitbit versa showed idid it and said it was connected the whole time. I stopped differnt times to check it.then I exited the exercise and the whole thing is gone. I'm trying to log it manually but it is not accurate to what I had done during the ride because of my heart rate and speed.
05-15-2020 15:23
05-15-2020 15:23
Do you know if someone from Fitbit actually reads these? Or what is the best way to reach them?
Best Answer05-15-2020 15:27
05-15-2020 15:27
Best Answer05-15-2020 15:28
05-15-2020 15:28
I emailed Tec support two days ago and still no reply?
The connection and battery seem really bad so may send it back.
Best Answer05-26-2020 11:19 - edited 11-28-2023 01:28
Hello guys. We apologize for the late response. I'm sorry to hear that you're having issues with the connected GPS on your Versa smartwatches.
As @Rich_Laue mentioned, please know that all devices with GPS sensors require a direct path to GPS satellites to calculate location. A weak GPS signal might affect the accuracy of your route and other activity data. Your device uses your step count to calculate distance until it finds a signal, so the total distance calculated for a workout may be slightly less accurate when GPS isn't available for the entire time. To learn more, see GPS.gov.
We suggest you to update your Fitbit app. Note that we released new versions of the Fitbit app on May 12, 2020 for Android (version 3.21) and for iOS (version 3.21) on May 19th. This version we fixed some bugs and made stability improvements. For more information, see: What's changed in the latest release of the Fitibit app? and How do I update the Fitbit app?
Hello @Sumo75. We really apologize for the delayed in the email you sent to our Customer Support Team, due to recent events affecting our operations, support options are limited and wait times are longer than usual. I've seen that they reached out to you on May 23rd but haven't heard back from you yet. If you still need help, please check your inbox and reply back to the email you received so our team can continue assisting you.
I'll be around if you have any questions present.
Best Answer05-26-2020 11:40
05-26-2020 11:40
Best Answer05-26-2020 11:56 - edited 11-28-2023 01:28
Hi there @Spapp07. I totally understand where you come from. I'm glad to hear that you haven't had an issue after restarting your phone and your Versa.
Actually, I always do a restart on my electronic devices, e.i phone, tv, computer, etc after an update, they need to refresh everything to operate great after the new fixes and improvements added in the version.
I'll be around if there's anything else I may do for you. Have a good day!
05-26-2020 13:27 - edited 05-26-2020 13:31
Hi Marrie thanks for the reply. I have done all the above but still didn't work so I sent the versa back and got another one this is still the same! The odd thing is when walking the same route it works fine but on bike it loses connection and will not connect back to the phone I just says connecting.....
This seems to be a bug on biking only? The phone GPS is great on the same route via Strava with no black area's! I know how GPS works as I fix car GPS faults for a living.
I really love the versa 2 but still have to take my Garmin out for my rides as I just can't trust the Fitbit versa.
Thanks for the input, any ideas? Seems like a software fault to me as it's only on the bike mode?
Best Answer05-26-2020 14:04
05-26-2020 14:04
My brother has the same issue with his Versa
Best Answer05-26-2020 14:11
05-26-2020 14:11
Not just me then!😆👍🏻
Best Answer05-28-2020 04:14 - edited 11-08-2023 02:15
Hello there @Sumo75, thanks for getting back and for the update. I've seen that our Support Team has replied to you after your last post here. I'd suggest to keep your conversation with them as they'll know what's the next step to try after everything you have done so far.
Let me know if you have any questions present.
Best Answer05-31-2020 06:11
05-31-2020 06:11
Hi Marrie, I sent a reply to the Tec support on the 26th and have heard nothing from them yet? How long does it take to get a reply?
Getting fed up with this now!
Best Answer05-31-2020 10:41
05-31-2020 10:41
Lots of us are having problems. It’s your last update that’s the problem!
Best Answer05-31-2020 14:34
05-31-2020 14:34
Same issue with my Versa2! This has happened twice in the last week with tracking bike rides. I make sure the GPS is connected before I start the ride. It doesn't ever say "reconnecting." It tracks my heart rate and everything, But the map never shows up in the fitbit app. However, it WILL show up on the fitbit dashboard on the computer, and the map shows up on Strava just fine.
I am wondering if it is more of a Fitbit app issue. I restarted both my phone and Versa2, AND uninstalled and reinstalled the Fitbit app in case that was the issue. Still not resolved. I have an Android/Google phone.
Best Answer05-31-2020 14:42
05-31-2020 14:42
