04-08-2018 09:47
04-08-2018 09:47
Fitbit Versa is saying not charging - not enough power at the source. Have tried on a laptop, desktop, USB plug and USB plug socket. Anyone else having the same issue? Thanks in advance
06-09-2019 14:52
06-09-2019 14:52
Didn’t work.
07-08-2019 20:48
07-08-2019 20:48
My Versa won't charge. It showed 90 percent this morning then just died. I have tried to reset. Cleaned it. Left on the charging cradle. A big concern now is that as I try to charge it the actual device is becoming extremely hot and if actually burned my finger when I removed it from the docking cradle. It becomes.extremely hot in a matter of a minute. So frustrated.
07-08-2019 21:04 - last edited on 05-22-2020 19:34 by LiliyaFitbit
Call customer service. They’ll send you a new charger, free and fast. I wouldn’t chance using that one.
Sent from my iPhone
07-09-2019 06:05
07-09-2019 06:05
07-09-2019 10:52
07-09-2019 10:52
07-09-2019 11:49
07-09-2019 11:49
07-09-2019 15:48 - last edited on 05-22-2020 19:34 by LiliyaFitbit
You’re welcome. I had to replace my original charger as well.
Sent from my iPhone
07-18-2019 11:04
07-18-2019 11:04
You ever fixed the problem if so how did you get it fixed
07-18-2019 11:15 - last edited on 05-22-2020 19:34 by LiliyaFitbit
Simple fix. Contact customer service. They are aware that there are defective chargers out there. They will send you a new one very quickly.
Sent from my iPhone
07-18-2019 11:31
07-18-2019 11:31
07-18-2019 16:41
07-18-2019 16:41
07-19-2019 02:57
07-19-2019 02:57
08-21-2019 05:56
08-21-2019 05:56
Same problem, get the Message Fitbit Versa is saying not charging - not enough power at the source.
Charging in a socket in the wall , have also tried my computer. Versa is empty of battery so I cant Access it to restart it. Anyone With a quick fix for this issue?
09-06-2019 13:54
09-06-2019 13:54
I purchased a new charging station for the Versa from Fitbit. Mine recently started to give the not enough power error message. I figured it was the station because my daughter's station would charge my Versa. I read many of the posts. I even tried taping the Versa to my Blaze charger. No luck. They I taped the Versa down on the Versa charger and it charged up. I have a roll of painters tape ready to tape the watch in the station.
09-06-2019 14:06
09-06-2019 14:06
09-06-2019 17:49
09-06-2019 17:49
09-07-2019 06:16
09-07-2019 06:16
Thanks for the info. Rocking the watch into place seems to make it happen.
09-24-2019 18:11
09-24-2019 18:11
Yes, I am having the same problem too!! I too restarted it and tried different plugs and no luck!
09-24-2019 20:37 - last edited on 06-19-2020 18:22 by LiliyaFitbit
contact customer care. You may need a new charger. They will send one out quickly.
Moderator edit: format
11-01-2019 15:11
11-01-2019 15:11
I did they tested it said it was defective but that the 1 year warranty had just went out a month ago. Will never buy this again worst product ever.
