04-08-2018 09:47
04-08-2018 09:47
Fitbit Versa is saying not charging - not enough power at the source. Have tried on a laptop, desktop, USB plug and USB plug socket. Anyone else having the same issue? Thanks in advance
08-23-2018 07:58
08-23-2018 07:58
Good deal! Thanks for the tips.
09-05-2018 00:35
09-05-2018 00:35
My versa isn't charging. Just started doing this yesterday. I tried connecting through outlet, laptop, desktop, TV and power source. None are working. I restarted, reset, cleaned connectors, nothing is working. Any advice would be helpful. In the meantime I'm using my charge 2, and not getting notifications.
09-05-2018 06:33
09-05-2018 06:33
09-05-2018 14:39
09-05-2018 14:39
09-05-2018 15:29
09-05-2018 15:29
09-05-2018 16:17
09-05-2018 16:17
09-05-2018 16:58
09-05-2018 16:58
09-05-2018 18:31
09-05-2018 18:31
09-05-2018 19:26
09-05-2018 19:26
09-06-2018 03:17
09-06-2018 03:17
09-06-2018 07:14
09-06-2018 07:14
09-11-2018 16:23
09-11-2018 16:23
I am having the same issue. It appears that all the gold contacts are intact on charger and watch. When I put the Versa on the charger it shows that it is indeed charging, but it actually isn't. Did yours show that it was charging even though it wasn't? Went through all the hoops that were suggested. Thoughts?
09-11-2018 16:31
09-11-2018 16:31
09-11-2018 19:33
09-11-2018 19:33
09-23-2018 09:07
09-23-2018 09:07
I'm having the same issue. I even purchased a new charger. My versa has been dead for 2 days and no matter what it won't charge. I've tried cleaning it and different ports.
09-24-2018 09:21 - edited 09-24-2018 09:24
Mine is actually working better then ever now. I reset the versa to factory settings.
I also updated my fit bit app on my phone.
After I reset the versa and updated the app it still wasn't charging. I turned off the versa and stuck it on the charger and let it sit. When I came back it had charged some. I took it off the charger, turned it off and stuck it back on the charger. Working very well now. Try this and see if it fixes your issues. If not I would get warranty information and send it back in. Hope this helps!
09-24-2018 12:52
09-24-2018 12:52
Hi, I was sent a replacement and all is well for now. Thank for responding.
09-24-2018 18:12
09-24-2018 18:12
I had that problem. After trouble shooting with customer service they sent a new watch. The design had changed and fit the cradle better.
09-28-2018 14:07 - edited 09-28-2018 14:20
Interesting. My watch totally went dead two weeks ago. Tried charging it in both my and my wife's charging hub. I'll receive a new watch module three weeks after it first went dead. Found out this morning that my wife's watch now isn't charging - 0% on the battery. When probing the terminal contacts in the charging cradle, the right most pin is 4.64V with ground on any of the other three terminals. Both charging cradles read 4.64V. Has anyone else measured their terminal voltages? Based on the majority of posts here, we might be better off getting a cheap 3rd party charger.
10-11-2018 05:23
10-11-2018 05:23
Mines not charging either. Just had it two weeks. Being sent instructions for a factory reset. Sounds like a systemic fault to me.
