Versa not connecting to WiFi
Have 2 previous Fitbit which worked with my iPad, have now purchased Fitbit Versa which will not pair with iPad or to be more precise will not connect with WiFi. Any ideas?
5 REPLIES 5
Check to make sure your iPad is connected to the lower end WiFi connection. If you have WiFi connecting at 2.5 mhz or 5.0 MHz it won’t work on the higher one, it needs the lower connection speed.
Correction: the amounts are usually, 2.4 ghz or 5 ghz.
It's great to see you here @Aljar and @Runtu thanks for stopping by.
If you are having issues with your Versa connecting to WiFi, I recommend taking a look at the help article Why won't my Fitbit watch connect to Wi-Fi? and follow the instructions provide there.
Let me know the outcome. Robot Happy
Hi so frustrated eventually contacted Fitbit support who said as I have 1st generation I pad will not pair suggested I pair with computer but it keeps asking for a dongle any suggestions
Have been told Versa not compatible with 1st generation I pad
Contacted Fitbit support who established I had 1sts generation I pad which does not support Versa watch .have now been told to download on computer but will need to buy dongle .
regards carol
