08-15-2020
07:06
20:02
EstuardoFitbit
08-15-2020
07:06
20:02
EstuardoFitbit
Hi, i use an s7 and a versa. when i bought my versa (an year back) it used to sync with my phone. however a couple of months later it stopped syncing. i tried re-installing the app and even factory resetting my versa but it does not sync. my versa does sync with my ipad though. any advice ? i am contemplating to shift to a xiaomi band now due to these issues.
08-15-2020 13:45
08-15-2020 13:45
Have you setup the Versa again, you removed it from your account with the factory reset. Which BTW doing so will only add problems
Best Answer08-16-2020 04:14
08-16-2020 04:14
Yep, removed it and did a factory reset and resetup from scratch.
