06-01-2020
12:59
06:07
JuanJoFitbit
06-01-2020
12:59
06:07
JuanJoFitbit
I’m a new Fitbit user, I have been using my Versa for 2 weeks now and the heart rate is constantly on and off. The BPM is not visible on my Versa, occasionally the heart rate does decide to come on, but it’s very temperamental and soon goes back off! Should the BPM always be displayed, as I really need this for accurate work outs.
I have shutdown, turned heart rate on and off, done a full reset, swapped from dominant to non dominant arm, wiped and cleaned the watch/band but the heart rate is still not working!
Also, my sleep score has also only worked twice in the past 14 days. I’m not sure if this is because the heart rate isn’t working.
Any help much appreciated as I’m wishing I hadn’t if wasted £150 for a device that will only count my steps 😞
Thank you in advance
Moderator edit: format
06-11-2020 06:06
06-11-2020 06:06
Hi @RebeccaFlower, welcome to our Fitbit Community! I'm sorry to hear that your Fitbit Versa stops tracking your heart rate. I totally understand how you feel about this and I appreciate your time spent trying to get this issue resolved.
I'd like you to try a factory reset. To do so on your device, follow the steps below:
Finally, monitor your watch for the next 24 hours and see if the issue gets fixed.
Keep me posted on the outcome.
