11-28-2018 12:01
11-28-2018 12:01
11-28-2018 15:05
11-28-2018 15:05
@Joyce42 A few questions: have you tried rebooting your Versa several times in a row by pressing and holding the left and bottom right buttons until Fitbit logo flashes? Are you using any 3rd party clockfaces? Some of them are not optimized and especially when running in the background can drain your battery. Finally, does your Versa sync properly?
11-28-2018 15:05
11-28-2018 15:05
11-29-2018 04:48
11-29-2018 04:48
@Joyce42 Welcome to the Fitbit Community! It's great to have you here! Sorry to hear that your Versa isn't holding its charge. Please do let us know the answers to the questions @Marrrmaduke asked so we have more information about this. You can also try cleaning the contacts including using cotton with rubbing alcohol then charge it by plugging it for a couple of hours directly to your computer's usb port (try different ports) or use an UL listed usb wall adapter. After this restart your device and see how it behaves.
Let me know how it goes!
11-29-2018 05:08
11-29-2018 05:08
12-16-2018 15:22
12-16-2018 15:22
Hi I am having the same issue with my Versa not holding a charge. I have already done everything suggested here on multiple forums without any success (I am using a FitBit clock face, have turned off all day sync, all notifications and I am not using any other apps). I am very disappointed with the Versa so far. any additional help would be appreciated!
Best Answer12-16-2018 21:43
12-16-2018 21:43
@ReCap At this point I would recommend performing a factory reset. This will force Versa to upgrade to the latest firmware. Also, this will erase data from your tracker, so please sync first. You will also need to delete your tracker from the Fitbit account (in the Fitbit mobile app) and your Paired Devices list in your phone Bluetooth settings. You can perform factory reset by going to Settings on your Versa, scrolling down to About and tapping Factory Reset. Once Versa resets to factory defaults, you will need to set it up again by adding it as a new device in the Fitbit mobile app. Please let me know how it goes.
12-17-2018 15:36
12-17-2018 15:36
Best Answer12-17-2018 15:39
12-17-2018 15:39
Hello I have tried everything you stated in your post. After the factory reset the Versa will still NOT fully charge to 100%. I have had it on the charger for over 2 hours. The battery also when from 99% down to 70% in 2 hours during the day before I did the factory reset. I am very dissatisfied with this product and will not recommend it! Do you have any other suggestions???????
Best Answer12-17-2018 15:42
12-17-2018 15:42
@ReCap How long does it last after the factory reset? Also, does it sync without issues?
12-17-2018 15:46
12-17-2018 15:46
I did the factory rest about 3 hours ago and it is still on the charger -still not fully charged-so I don't know yet how long it will last since the reset. The fact that it will not reach 100% charge doesn't seem like a good sign. It is becoming obvious it is defective.
Best Answer12-17-2018 15:53
12-17-2018 15:53
@ReCap My versa does not charge to 100% but to 99 if i keep it 2-3 hours. At the same time the battery lasts 5 days with using all the features. I charge my Versa overnight. I recommend leaving it for 4 hours or simply removing from the charger when it's 99% and seeing how long the battery lasts. If it still dies quickly, you will need to reach out to Customer Support.
12-17-2018 15:57
12-17-2018 15:57
OK Thank you. I will test it out and let you know how it goes!
Best Answer12-17-2018 16:01
12-17-2018 16:01
@ReCap 👍👍👍 Please do.
12-18-2018 14:49
12-18-2018 14:49
Hi Marmaduke Day 1 so far so good! Holding charge and syncing ok 😊
12-18-2018 14:51
12-18-2018 14:51
@ReCap How many hours have passed since unplugging and what's the battery % so far? 😊
12-18-2018 15:10
12-18-2018 15:10
It has been unplugged for about 19 hrs the battery level is at full 👍🏻 You are a genius! TY !
12-18-2018 15:12
12-18-2018 15:12
@ReCap I'm basking in the glow of your praises. 😊😊😊🤗😋 Please do keep me posted as I am very curious how long the battery will last on a single charge! Happy holidays! 🎄
12-18-2018 16:39
12-18-2018 16:39
Thank you and Happy Holidays to you as well!! I will keep you posted! 🎅🏻🎄 you are on the “nice” list!
12-18-2018 16:52
12-22-2018 04:30 - edited 12-22-2018 04:31
Hey Marrrrmaduke 😊 update with my Versa! All is well 👍🏻 It is tracking and syncing well and the battery is lasting as I hoped it would so far. All apps are synced and working as well! I thank you for all your help!! May you have the best of the holidays! 🎄🎄🎄 thanks again!!
