08-10-2019 14:29
08-10-2019 14:29
My Fitbit versa is no longer holding its charge for more than 4 hours. How can I rectify this? It used to just need charging every few days?! I can’t really wear it anymore as it just dies in the middle of the day.
08-10-2019 18:04
08-10-2019 18:04
Hi @Hadders1st I have flagged a moderator to ckme and help you
Helen | Western Australia
08-10-2019 18:34
08-10-2019 18:34
Hi
i have the same problem. The screen seems to keep a background blue light running which drains the battery. Have tried changing the clock design but no use
08-10-2019 19:22
08-10-2019 19:22
My Versa also died in in about 20 hours with light usage. I've noticed it has been dying very quickly over the last two weeks. Really annoying 😕
08-10-2019 22:14
08-10-2019 22:14
I too am having a similar problem, though mine will last about a day.
I charged it on July 31st, wore it for several days and had to charge it on Aug 5th. Since then I have had to charge it every single day. I have tried rebooting it, I have tried factory resetting it, I have tried a different watch face.
08-11-2019 09:55
08-11-2019 09:55
Welcome to the Fitbit Community! It's great to have you here @Hadders1st @ShaunLangers and @lgmartian! Nice to see you again @Tom.lipscomb and @NellyG.
Sorry to hear that your Versa isn't holding its charge. You can also try cleaning the contacts including using cotton with rubbing alcohol then charge it by plugging it for a couple of hours directly to your computer's usb port (try different ports) or use an UL listed usb wall adapter. After this restart your device and see how it behaves.
Keep me posted on the resolution.
08-12-2019 16:52
08-12-2019 16:52
Tried all those things, seems to lose about 10-15% in an hour just on my wrist. I factory reset it and that didn't help at all. I've cleaned the pins, let it sit on the charger for a bit longer to make sure it's well and truly at 100% and nothing seems to work.
08-12-2019 16:59
08-12-2019 16:59
For my versa I don’t think it’s the battery, it’s that the screen is constantly on. Even when I turn off the screen a light blue light keeps being omitted which I think drains the battery...?
08-13-2019 12:53
08-13-2019 12:53
Hello - thanks for all of the advice. I’ve tried all of the suggestions but nothing is solving this unfortunately. I can’t use it for anything ie alarm, watch, timer, step counter, notification when I receive a text message - the charge usage when fully charged is now only about 3 hours - absolutely useless 😖🥴😫 refund or replacement needed I think.
08-13-2019 14:08
08-13-2019 14:08
How do we return our watches or get them swapped
08-13-2019 17:01
08-13-2019 17:01
I'd like to know too
08-14-2019 17:27
08-14-2019 17:27
08-17-2019 08:05
08-17-2019 08:05
Update: I went on a live chat and then emails with Fitbit.com and they asked me to charge the versa fully and then throughout the day and sync my versa 5-7 times until the charge had depleted. After doing this they were able to test things their end and could confirm that the battery was draining rapidly through the day. They said that I was eligible for a replacement and so I will have a new Fitbit versa within the next 5 working days. I’m a happy customer - great service from Fitbit.com.
08-17-2019 08:31
08-17-2019 08:31
I have the same problem. I have a replacement Versa because my first one stopped working and now this one dies after only wearing it for a day after being charged. Not sure if it would still be covered by the guarantee?
08-17-2019 09:15
08-17-2019 09:15
You're lucky ! I had the same battery issue as everybody else on this page and I cannot have a replacement because I bought my watch over a year ago so theres no more guarantee. I'm pissed.
