08-12-2019
18:12
08:36
08-12-2019
18:12
08:36
I wore my versa while swimming, dried it off as directed now it will not hold a charge (less than 8 hours) and there is condensation on the back sensor. Any help apperciated
08-13-2019 00:26
08-13-2019 00:26
Hi @TrishP417 I have flagged a moderator to come and help you
Helen | Western Australia
08-13-2019 05:29
08-13-2019 05:29
08-13-2019 08:41 - edited 03-27-2024 12:52
Welcome to the Community Forums @TrishP417!
Please restart your Versa as described in this help article. After this, check out if the display of your Versa comes back to life. For more information about wearing your Fitbit device, see our Wear and Care page.
If you see condensation inside the screen, dry rice may work temporarily but the problem is likely to reoccur. In most cases water damaged trackers aren't covered under warranty but it depends on the model. Contact Customer Support if you're unsure.
Thanks for your help @NellyG.
08-13-2019 09:27
08-13-2019 09:27
Nope- now it isn’t even charging
08-13-2019 09:28
08-13-2019 09:28
The link for customer support goes to a sales force website- is the log in the same as the Fitbit app?
08-15-2019 09:49 - edited 02-03-2024 07:30
Hello there @TrishP417, thanks for coming back. I'm sorry for the mistake in the link I've provided, I have included the correct one.
I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you soon!
Let me know if there's anything else I may do for you in the meantime.
