08-13-2019 18:42
08-13-2019 18:42
I just bought a versa, to replace a charge 2. I wear it on my ankle when bike riding, but the versa isn’t able to track my heart rate. It jumps randomly to my resting hr over and over when I’m riding. I never had a problem with the charge 2 on my ankle. It tracked heart rate accurately.
I’ve tried moving it around, tightening and loosening it, to no avail.
Any suggestions?
08-13-2019 23:18
08-13-2019 23:18
Hi @Ktothemuse The tracker is made to wear on your wrist, so if you want all the functions to work then that is where you should wear it. Why wear it on your ankle for biking anyway? It picks it up well when wrist worn (well mine does).
Helen | Western Australia
08-14-2019 00:03
08-14-2019 00:03
@NellyG Bike & spin class riders wear it on their ankles, tucked into socks, taped to their ankles as the app dashboard will not record correct mileage for that bike ride or spin session as there is no step count algorithm to calculate otherwise.
08-14-2019 00:24
08-14-2019 00:24
Umm yes, but you are still not getting correct distance by counting bike revolutions as steps
08-14-2019 02:26
08-14-2019 02:26
Better than nothing though. You wear tracker on your wrist & you will be lucky to get 0.58 miles returned for a 33 mile bike ride as that is what happened to me very recently.
Just moved to Garmin Fenix 5 over this.
08-14-2019 17:09
08-14-2019 17:09
When I wear it on my wrist for bike rides, it doesn’t register any steps. I want the hard work on the bike to count toward my daily step count, so I wear it on my ankle. Many people do this 🙂
08-14-2019 17:10
08-14-2019 17:10
I’m not worried about it having the correct distance.
Best Answer08-14-2019 17:12
08-14-2019 17:12
I don’t understand why my versa isn’t tracking heart rate while on my wrist. I’m wearing it in a soft stretch you headband that I double up on my ankle, the same way I wore the charge 2. My next attempt will be using a strap big enough for my ankle, to see if that makes any difference.
Best Answer08-14-2019 17:48
08-14-2019 17:48
@Ktothemuse I use surgical tape!
