04-20-2018 12:00 - last edited on 04-24-2018 06:25 by HeydyF
My new versa isn’t detecting or saving my sleep information
if someone could help would be grate
thanks
05-15-2020 15:00
05-15-2020 15:00
I've tried everything suggested to get my premium sleep details to appear instead of just basic.
I've been using this versa 2 watch since Christmas and it's worked perfectly till now I've had 6 days in a row with just basic readings it's not very old 5 months should I ask for a replacement?
05-15-2020 16:02
05-15-2020 16:02
05-15-2020 16:22
05-15-2020 16:22
05-15-2020 19:17
05-15-2020 19:17
05-23-2020 14:07
05-23-2020 14:07
I've had this problem for a month now. Lately it is not also logging my heart rate. I've had my Versa 1.5 years ago, as a Christmas gift in December 2018. I have tried turning off and on, resetting it, changed USB port hook up, and plugged to different electrical outlet. I miss my Charge 2 which I gave away when I received my Versa. Is there any other way to fix this? Thank you.
05-23-2020 14:47
05-23-2020 14:47
05-23-2020 18:25
05-23-2020 18:25
05-24-2020 07:02
05-24-2020 07:02
Unfortunately not that I have discovered. This watch is a disappointment when it comes to sleep stages and heart rate and this is one of the main reasons for my purchase. I have had mine 2 years now and I have issues regularly.
05-24-2020 07:34
05-24-2020 07:34
05-24-2020 07:37
05-24-2020 07:37
It is so disappointing
05-24-2020 07:48
05-24-2020 07:48
05-24-2020 07:58
05-24-2020 07:58
Nope not that I an aware of. Seems to only do what it wants when it wants.
05-27-2020 18:41
05-27-2020 18:41
Bought my Versa 2 at Costco not even 2 weeks ago and I'm already running into this issue. The sleep tracker is why I bought it and I'll either try to return it or put it in my night stand until I have the courage to pay the money for an Apple watch. My wife has an Apple watch and has no issues.
05-27-2020 21:34
05-27-2020 21:34
05-28-2020 09:38
05-28-2020 09:38
06-02-2020 07:02 - edited 06-02-2020 08:32
Hi there @Janetbb, welcome to the Community Forums. I'm glad to hear that you're now receiving your sleep stages. Thanks for sharing the steps that worked for you and for your time while helping others as @curious1 did with you.
Hello @DDMom01, @elizawitch, and @RunningwithNike, thanks for stopping by and reporting the issues you're having with the heart rate and sleep stages. I appreciate your efforts in troubleshooting this prior to posting here.
Please note that our main purpose is to avoid negative experiences to our customers, we're always willing to help and provide troubleshooting steps. I'd like to give thanks for the feedback you've provided towards our product. Know that we provide feedback to our team based on community posts and we are always working on improving our devices and overall environment based on that feedback.
As you may know, sleep stages are based on heart rate data, so make sure that you're getting a solid heart rate reading , since sleep stages requires consistent HR. For best results, wear your device higher on your wrist (about 2-3 finger widths above your wrist bone). The band should feel secure but not too tight. Also, double check that your watch is charged up.
Additionally, I'd recommend checking the following that could be preventing you from receiving sleep stages:
For more information about why you see your sleep pattern, tap or click the sleep record that shows your sleep pattern.
If after testing the above suggestions for the next couple of nights your watch is still not giving your sleep stages or heart rate, I'd recommend doing the following steps:
Also, for more detailed information, see: What factors can affect my heart-rate reading on my Fitbit device? or What should I know about sleep stages?
Let me know how it goes.
07-15-2020 15:13
07-15-2020 15:13
I have this situation and I obtain my FITBIT Versa 2 like one week ago. I have problem with get correct HRV and/or Sleep Tracker. I not see Graph REM ... and how I pause step tracker because when I Work in my office mark more steps and doesn't happens. Any suggestion?
Because it's not get a good resolve my issue I think to make a refund with this device.
07-15-2020 20:03
07-15-2020 20:03
07-16-2020 02:04
07-16-2020 02:04
I just bought my Versa 2 3 weeks after buying the Charge 4 as this was too small. It consistently fails to log sleep. My charge 4 was fine.
I factory reset, I wear it in the right place
I switched off the heart rate monitor and back on gain
I even set it to sensitive monitoring.
Clearly it is faulty and would like it seen to and swapped out
I have tried to chat online and it crashes if it even loads up
I am at my whit's end in how I get this sorted. I love in the UK but bought this in Norway so I can't just take it back.
Please would someone help advise on how I can get through to Fitbit...their customer service is not greta if I can't contact them efficiently.
Thank you in advance.
07-16-2020 02:55 - edited 07-16-2020 03:06
Hi @Jaymark, if chat or email doesnt work you can always try calling them, details can be found here: Get Support. Good luck! I had a good experience with their call center myself.
