07-19-2018
22:07
08:35
HeydyF
07-19-2018
22:07
08:35
HeydyF
Hi I am trying to pair my versa with one plus 2 but no luck. I tried different options but it's not pairing with my one plus 2 device. I am thinking for returning my versa. It's very sad that that versa only supports the one plus one.
Best Answer07-20-2018 08:33
07-20-2018 08:33
Hey @Bhushan007, welcome aboard! This phone, the One Plus One, isn't on the compatible devices list. Just like you mentioned, only the One Plus One was officially released as compatible device as you can see in this help article, however, if your current phone has Android OS 4.4 (KitKat) or higher, it might connect with your Versa. I don't know if you already tried that out, but I'd like you to let me know if you already reviewed the troubleshooting in this help article: Why can't I set up my Fitbit device?.
Remember that you can also use a computer to pair your Versa. So please take a look at this other help article: How do I set up my Fitbit device? to do so.
Let me know how it goes!
Best Answer09-26-2018 15:16
09-26-2018 15:16
Hey HeydyFitbit,
I have been gifted with the versa and now found it is not compatible with the phone, which means that, eventhought i can pair it with the computer, I lose most of the capabilities anyone would choose a versa model for (which is a huge economical difference).
I have check the compatibility list and it looks like the list of phones you could easily get. If you would tell be about android versions compability that would have sense. Do Fitbit plan to increase compatibility to Android 6.0.1 Marshmallow or should we assume versa evolution is already dead?
Best Answer09-28-2018 06:23
09-28-2018 06:23
Hello @srhappy, welcome to the Community! Let me ask you this, what is the type of phone that you have? Even if you have checked that it doesn't appear on the compatible devices list, you can troubleshoot it by following the instructions in this help article: Why can't I set up my Fitbit device?
Best Answer09-28-2018 11:34
09-28-2018 11:34
Best Answer09-29-2018 07:12
09-29-2018 07:12
Thanks for your reply, and the clarification @srhappy! In regards of your question, I don't have a specific date for this phone model, the OnePlus 2, to be released as full compatible. So In the meantime, if by any chance is possible, to keep using another compatible device to sync your Versa. And stay tune about the compatible devices list.
If you have further questions, keep me posted!
Best Answer05-25-2019 12:39
05-25-2019 12:39
When will the one plus two phone be supported. I have been given a versa but can’t set it up. What a waste of Fitbit.
