07-16-2018
05:40
04:58
AlejandraFitbit
07-16-2018
05:40
04:58
AlejandraFitbit
I have a Galaxy S7. Up until yesterday afternoon I have not had a single issue. Now I'm only receiving text notifications, Gmail, breaking news. No other email or phone calls aside from a notification that I've missed a call. I've reset the watch, reset my phone, made sure everything is on.Turned Bluetooth on and off. Not sure what is going on. Any help would be much appreciated.
11-17-2021
09:09
08:12
11-17-2021
09:09
08:12
Thanks for getting back to us and for sharing the steps that worked for you in order to receive notifications @Zaniest.
I marked your response as the best answer and hope that this information helps other users.
06-08-2022 16:05
06-08-2022 16:05
This is the only thing that worked for me:
- First make sure that your fitbit app is updated and everything
- Once that's done, go to the app, select your device and click on refresh button from the "Sync Now" option
- After that, go to the top right corner of that same page, click on the trash can, and unpair your device from the app
- After it unpairs, re pair it again where it says "Set up a Device".
- From there click on whatever device you have that your re pairing and then follow the instructions that the app tells you after that.
- Once everything is done and set up, make sure you set it to get notifications for messages and phone calls again.
- You can now send yourself a test phone call or have someone call you and you will see it pop up and vibrate on your device.
06-09-2022 07:05
06-09-2022 07:05
Welcome to the Fitbit Community, @cmeehan. Thank you for sharing the steps that worked for you.
I´m sure they will be useful for other users.
Keep on visiting the forums.
