04-30-2018
03:02
08:06
AlejandraFitbit
04-30-2018
03:02
08:06
AlejandraFitbit
I have managed to sync my Versa to my Android. I am receiving notifications for whatsapp, sms messages, Gmail, calls. But for some reasons, I cannot seems to get notifications from Outlook or Outlook Calendar.
I have checked that the notifications is on in the phone setting and in the Fitbit app setting. Can someone help me out with this?
Thanks.
05-02-2018
08:12
08:07
05-02-2018
08:12
08:07
A warm welcome to the Community @Coriela.
Thanks for troubleshooting this by yourself. If you aren't receiving your Outlook notifications, I recommend going to the "App Notifications" from your Fitbit app, disable Outlook notifications, restart your phone, go back to the Fitbit app and enable the notifications you want to receive.
Also, check that your Fitbit app is updated by following the instructions provided in the How do I update the Fitbit app for Android? post.
I hope this helps, let me know the outcome. ![]()
Best Answer05-20-2018 08:34
05-20-2018 08:34
Hello,
I did what was suggested, but still not getting calendar/meeting/event reminders on Versa. Any other possible solutions?
11-07-2018 17:35
11-07-2018 17:35
Did you ever figure this out? I’m having the same issue.
01-02-2019 07:34
01-02-2019 07:34
I'm having the same problem. Notifications are turned on properly, other notifications are working. But Outlook and calendar events will not come through. This is a pretty important feature to have working. Any solution??
Best Answer01-25-2019 12:00
01-25-2019 12:00
Same problem - I get Outlook calendar notifications but not email. Planning to return my Versa if I can't get this figured out.
Pixel 2 XL (stock, not rooted)
Outlook App installed on phone
Have tried every combination I can think of in the FitBit App notifications section.
If I set email default to Gmail, they come through fine. Same for texts. But for Outlook, no matter what I do, don't get notifications for email.
Best Answer02-20-2019 17:08
02-20-2019 17:08
Hi Everyone,
I was having the same issue today when I first got my Fitbit Versa. I could get notifications for everything except for emails; texts, phone calls, and gmail emails all came through instantly. I have a Pixel 2 XL running Android Pie. I tried Fitbit support online, but didn't get anywhere.
After I some trial and error, I was able to adjust the settings in the email app on my phone to get notifications on my watch. In the phone email app go to Settings>Notifications>New mail sound>Behavior. From that menu select either "Make sound" or "Make sound and pop on screen" to get your emails on the Versa. I initially had "Show silently," and could not get my mail on my watch. Toggling to either of those new options worked.
Because of this change your phone will now vibrate when your email comes through, and your watch will vibrate as well. In the past, my phone only showed an email notification and did not make a sound/vibrate, so this will take some getting used to. However, at least I know I can get my messages on my watch if I want them.
(For some reason I can't post my reply if I type the name of the phone email app, but I am referring to o u t l 0 0 k.)
10-16-2019 07:45
10-16-2019 07:45
After struggling with this for 2 days, I fiiiiiinally figured it out! My job switched to a secured version of Outlook. So my email notifications from my Android phone stopped coming through on my Versa. I went to the Playstore and downloaded Outlook again (in addition to the secured version for my job) and it worked! Hope this helps. Good luck.
10-18-2019 21:37
10-18-2019 21:37
So do you get your work email alerts on your versa or just your personal emails?
Best Answer10-18-2019 22:55
10-18-2019 22:55
Best Answer10-20-2019 16:16
10-20-2019 16:16
😔😔 Soooo.... My employer switched to a dual authentication app that includes Outliook. I found out that for security reasons, notifications will not be possible. We also don't even get notifications on our mobile phones. So, it doesn't sound like it will ever work.
Best Answer01-07-2020 11:46
01-07-2020 11:46
Same here, no Outlook notifications
I used a Pebble before and it was MUCH simpler. I've gone through all Fitbit settings and no luck.
Pls can support at Fitbit advise? It's quite annoying as I need meeting reminders, not emails.
Thanks
Best Answer01-07-2020 17:26
01-07-2020 17:26
Best Answer04-03-2021 18:09
04-03-2021 18:09
I use to get notifications until the latest update to my Samsung s21.
