06-19-2018 11:27
06-19-2018 11:27
I do 1 hour each day on the treadmill walking at 4.0 and elevation of 5-6
I set the versa app. exercise to treadmill and calories always agree with the treadmill. However, the distance is way off. The treadmill will say 5 miles vs. 3.5 on the versa.
I have been to several gyms in the past two weeks and same result. I wear the versa on my left wrist and do not hold on to the treadmill. I let my arm swing freely.
Best Answer06-19-2018 12:18
06-19-2018 12:18
@gman1107 Is the number of steps counted correct (that amount of time on a treadmill would be about 9000 steps for me, but I'm a tiny person with short legs, for reference)? The distance recorded is just the number of steps times your stride length, which is part of your profile. Stride length can be incredibly variable for a single person in different situations, plus a treadmill complicates it further, because it feeds the distance to you, so I mostly pay attention to the number of steps.
If the number of steps is correct and the distance is important to you, you can recalculate your stride length and change it in your profile. If the number of steps is incorrect, I can commiserate - there's something in my stride that causes my Fitbits to count fewer and fewer of my actual steps the longer I spend on my treadmill at a consistent speed. If I change the speed regularly - i.e. mixing walking and jogging - I don't have that problem.
Best Answer06-19-2018 12:58
06-19-2018 12:58
Best Answer06-19-2018 13:05
06-19-2018 13:05
@gman1107 are the steps on the versa correct?
Best Answer06-19-2018 13:15
06-19-2018 13:15
Best Answer06-19-2018 15:45
06-19-2018 15:45
@gman1107 If you keep the hand you wear the Versa on touching your body, or put the Versa in a pocket (you won't get heart rate) for a workout, that'll give you an accurate step count. Then you can compare it to the step count when you don't do those things.
Best Answer06-19-2018 15:58
06-19-2018 15:58
Best Answer06-19-2018 16:00
06-19-2018 16:00
@gman1107 I've given you the best suggestion I have. Fitbits count STEPS whether you care about them or not. Your stride length might be off. I can't help you any more.
Best Answer06-19-2018 17:06
06-19-2018 17:06
@gman1107 Also, your treadmill is wrong if it's telling you that you're walking 5 miles in an hour at 4 miles an hour.
Best Answer06-19-2018 17:26
06-19-2018 17:26
Best Answer08-15-2018 19:04
08-15-2018 19:04
Best Answer12-17-2018 10:54
12-17-2018 10:54
Since the Versa is not accurate, does Fitbit have a solution?
09-16-2019 14:22
09-16-2019 14:22
My versa is doing the same thing. 3 of 5 days it was dead on, the other 2 only a fraction
Best Answer10-09-2019 12:37
10-09-2019 12:37
Hi, my steps are correct so how do I calculate my stride please?
02-11-2020 15:31
02-11-2020 15:31
Try turning off bluetooth in your mobile phone or keep afar the phone from where you're doing treadmill...then manually set versa on exercise to treadmill mode and press on and off at start and after....this is to disable gps mode and count distance by steps x stride length....on gps mode while doing treadmill registers negligible distance as you are practically stationary as far as the sats see it
