01-04-2019 07:48
01-04-2019 07:48
Hi, the last two days the versa isn't recording my active mins, sleep or bpm. It is also not syncing the hourly steps. My phone is a Samsung A3 (2017). I have had the versa for about five weeks.
Best Answer01-04-2019 15:20
01-04-2019 15:20
@Ginge29 It's not recording sleep stages or active minutes because it is not recording bpm. Please go to Settings app on your Versa (swiping left), tap it and scroll down to heart rate. Please toggle it ON and OFF with a reboot of versa in between. You can reboot your tracker by pressing and holding the left and bottom right buttons until Fitbit logo flashes. Also, make sure the sensor lights are flashing, you're wearing Versa's band tight enough, and that Versa's battery is not critically low (anything between below 10-15) as the sensor may turn off automatically. I recommend toggling the heart rate settings ON/OFF, rebooting and placing on charger.
To restore the sync, please try this:
The trick here is to not pair in phone Bluetooth settings but rather let the Fitbit mobile app do that.
Additional tips if sync issues persist: If you have Wifi set up, go to Fitbit mobile app and remove it, then sync your Versa. I noticed that it causes issues for me. If you have other Bluetooth devices paired with your phone, forget them. One of them might be causing issues. Also, make sure Always Connected, Keep Alive Widget, and All day sync are enabled.
01-12-2019 22:15
01-12-2019 22:15
@Ginge29 Did you manage to make it work? 😄
